Tip & How-To about Cell Phones
How to keep your phone running smooth!
Phones are like computers in most ways, when you leave a computer on for an extended peiord it will run slow. Thsi is the same concept with cellphones try taking the battery out every other day and hlding your power button for 10-15 seconds, put the battey back in and turn it on, this will allow your phone to start fresh and you will notice the difference in speed. :)
Cell Phones Logo
How do I download photos from a Samsung sgh-a687 cellphone to my computer
hello, unless you have and older computer or a computer running windows 10 your shouldn't have a problem doing it, with your usb end of your power cable, it should sync automatically or under my computer you would see it and transfer from there. Unless you have a bad cable.
Jan 16, 2012 | Samsung Cell Phones
how to download a theme from computer to my nokia c3 phone?
Hi!
For you to install a theme to your handset, first, you need to download an installer (theme) to your computer, try www.mobile9.com, after downloading the file, locate it first, connect your cellphone using USB connector, then select MASS STORAGE on your handset, now, transfer the file to the cellphone's drive or memory card. after that, safely remove the handset from the computer, locate the file from your cellphone by going to the file manager and then run it.. if it shows error, try to download another one. by the way, the OS of your cellphone is SYMBIAN S40, so be carefull in downloading a file it should be in .NTH format. THAT's IT!
Please don't forget to click on 4 THumbs UP at the TOp!! THANKS!
Apr 09, 2011 | Nokia C3 Cell Phone
at first how to install the theme to device i.r Nokia 5233 from computer?
Hi!
For you to install a theme to your handset, first, you need to download an installer to your computer, try www.mobile9.com, after downloading the file, locate it first, connect your cellphone using USB connector, then select MASS STORAGE on your handset, now, transfer the file to the cellphone's drive or memory card. after that, safely remove the handset from the computer, locate the file from your cellphone by going to the file manager and then run it.. if it shows error, try to download another one. by the way, the OS of your cellphone is SYMBIAN S60 ver.9, so be carefull in downloading a file it should be in .SIS format. THAT's IT!
Apr 08, 2011 | Nokia Cell Phones
mobile file open slow
it is happening due to virus
format ur cellphone & memory card after saving ur data in ur computer
always use quick heal antivirus in ur computer
if u r satisfied with my answer then pls vote me
Jan 16, 2010 | Nokia N73 Cellular Phone
106 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
