Tip & How-To about Computers & Internet
Win XP Tip,
Insert your windows XP disc into your PC.
Click exit if your installation screen comes up.
Now go too your CD drive in *My Computer*. Right-click and select open.
Choose VALUE ADD\MSFT\NT BACK-UP FILE.
In the *files of type* drop down list be sure that *select all files* is on.
Click on the NTBACK-UP.msi file and click okay.
Click the finish button and now go over too the start button\ALL PROGRAMS\ACCESSORIES\SYSTEM TOOLS\ and there it is now.. BACK-UP FILES...
Great little tool that Microsoft never should have hidden.
Win XP Tip, Rename Multiple Files
A new, small, neat feature for winXP deals with renaming files. I personally have always wanted the OS to include a way to do a mass file renaming on a bunch of files. You can now rename multiple files at once in WinXP. Its real simple:
1. Select several files in Explorer, press F2 and rename one of those files to something else. All the selected files get renamed to the new file name (plus a number added to the end).
2. Thats it. Simple huh.
I would recommend that you only have the files you want to rename in the directory your working in. I would also recommend that until you get used to this neat little trick that you save copies of the files in a safe location while your getting the hang of it.
Ever wonder what's going on behind that splash screen? Well, now you can find out!
Right click My Computer, Properties, Advanced, Startup and Recovery, Edit. Edit BOOT.INI. Add "/SOS" right after "/fastdetect" with a space between. The line will look something like this:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /SOS
. Then you're finished. The first part, multi(0)..... may not be the same on your machine. Upon restarting, the splash screen will be gone. It can be re-enabled by removing the new switch.
