Tip & How-To about Computers & Internet
How to set up router
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for step bi step instructions
Computers & Internet Logo
no internet connection
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
i cant configure my mbr624gu router with usb 598 mobile 3g internet
Click here for step by step instructions
Dec 03, 2009 | Computers & Internet
can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
need security code numbers in order to install..usr5461 1.1
Are you looking for the wireless security key / password ?
That is set up on the router.
These are the settings of your router. To find out the code you will need to access the router set up interface.
Do you have any computer connected to the router or able to go online through the router ?
Use that computer to open the set up of your router.
Nov 13, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I LOST MY INSTALLATION DISK FOR MY ROUTER, IS THERE ANYWAY I CAN GET THAT DRIVER ONLINE?
This router does not need any drivers. The users manual can be found here: http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-366%20DX-WEGRTR%20combined%20-%20WEB.pdf
Without the cd you won't be able to use the easy setup wizard, but you can still configure the device. Starting on page 15 half way down it talks about setting up your router using the web-based advanced user interface. Using that information you should be able to configure your router.
Oct 11, 2008 | Dynex Enhanced-G Wireless Broadband Router
487 people viewed this tip
David Payne
David Payne
