Tip & How-To about Office Equipment & Supplies
HP Printer not printing all Models.
Any HP printer has a printer head if you run the ink cartridge out of ink you can burn out the printer head Also Trying to refill these print cartridges can damage the print head so it is best to replace the cartridge rather than refill. Most print heads cost $50.00 for the print head and can be replaced by the user if yo have some mechanical skill. Go to http://www.hp.com to see how to change print head for your specific machine.
red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
printer slow after putting in a refilled cartridge
Sounds like the TSR is out on your cartridge. The TSR is the heat sensor for your print head. If the TSR goes out it cannot tell the printer that the temp at the print head is at ok levels. So the printer assumes the print head is really hot and at risk of fusing its nozzles so it prints really slow (the faster the printing the hotter the print head gets). It is possible, but not very likely, that the ink in the cartridge is of such low quality that it is not cooling the print head properly as it flows through the nozzles. Thus the TSR tells the printer to print really slow so you don't burn up nozzles. If you got this cartridge refilled at a store or on-line I would return it and get your money back. I recommend Cartridge World for refills because if this happens to one of their refills they will give you a new refill at no charge.
Oct 15, 2009 | HP PSC 1610v All-in-One Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I do not have 3 at this time.
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: http://www.pokluda.cz/. You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Mar 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
Problems refilling the HP60 cartridge
had the same problem with this hp60 before .. so when i bought a new cartridge i refilled it before it runs dry ... i'm now on my third refill and it works on both black and color
Feb 13, 2009 | HP DeskJet F4280 All In One Printer InkJet
228 people viewed this tip
k24674
