Tip & How-To about Computers & Internet
Internet is too slow how to make it fast
Please reconnect your ethernet cable . Right click on the LAN connection icon and click on repair.. It will get clear otherwise,go to windows. then to Run . in run window type "cmd" you will get a window named command prompt. In command prompt , type ipconfig. Now you will get ip address of your system. Then type ipconfig/release to release your ip and after some time type ipconfig/renew .in command prompt...So you will be getting new ip and it will be faster.
Computers & Internet Logo
my acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
internet connectivity
Reconnect your ethernet cable . Right click on the LAN connection icon and click on repair.. It will get clear otherwise,go to command prompt, type ipconfig. Now you will get ip address of your system. Thentype ipconfig/release to release your ip and after some time type ipconfig/renew .in command prompt...So you will be getting new ip and it will be faster. Hope this will helps you...Thank you...
Oct 13, 2009 | Compaq Presario Notebook
internet is disconnected
If your LAN connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
Apr 19, 2009 | Acer Aspire 5315 Notebook
hey BIgz19
It is not illegal, of course!
I assume you do have an ADSL or Cable modem connected with LAN cable.
You connect your modem to the wall outlet/splitter with a telephone cable.
Then then modem is connected with LAN cable to your router's WAN port and then two PCs to any of 4 LAN Ports.
Please follow these steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect one PC to one of the 4 LAN ports of your Router with a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APPLY, and again APPLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable.
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the other PC and do the same above.
Connect the NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
You should check if both PCs are in the same WORKGROUP !
Right-click on My Computer, click Properties, then click 'Computer name' tab, and down on CHANGE. In the Workgroup field type the same as the Workgroup name of the other PC, then APPLY and OK.
This action need a REBOOT. Do reboot!
That's it!
Hope it helped.
Mar 16, 2008 | Edimax BR-6104K Router (br6104k)
no wireless
you have to renew the ip address.the easiest way to do this is restart the computer then try entering your net key.ALSO if you use a standard ethernet cable the computer may be trying to connect to the internet through that.what you want to do is disable the LAN connection in your network connections window and right click on the wireless connection icon and click REPAIR,this will renew your IP address also.If you do not know how to get to these settings go to START/ CONTROL PANEL/NETWORK CONNECTIONS then right click on your wireless connection then click repair.While your in that same window you can right click the LAN connection and disable it.To enable it simply right click the icon again and click enable.
Nov 14, 2007 | HP Compaq nc6000 Notebook
853 people viewed this tip
David Payne
David Payne
