Tip & How-To about Computers & Internet
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; about to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
Computers & Internet Logo
ERROR CODE 51.2M
Hi
A quick look on the internet told me that this is probably a HP ColourLaserjet series printer/copier, and have proceeded on this basis using the 5500 model. This particular code crops up on several models and the explanation is given below:
Description:- A printer error has occurred.
X Description: 1 scanner error 2 scanner startup error 3 scanner rotation error Y Description 0 no color K black C cyan M magenta Y yellow
Remedy:- 1. Press GO to continue. 2. Turn the printer off and then back on. 3. Reseat the connectors between the laser/scanner (J74 - J77) and DC controller PCB (J1106 - J1109). 4. Replace the defective laser/ scanner assembly. Calibrate the printer after replacing the laser/scanner. 5. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
I obtained this from the link below:-
Error Codes HP Color LaserJet 3550 Code 51 XY
for the 5500, but there are drop down menus above the error details which enable you to change the model number to your specific machine and then you will get the exact requirements. I recommend you do this as although the error code description for other models is the same, the PCB numbers under the "Remedy" are different for different models. You can also download a service manual from this site using the link at the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Office Equipment & Supplies
003-345
Please reply with exact error so that we can find solution....................thanks.
Jul 02, 2008 | Dell 5110cn Laser Printer
microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
How can I Download the Audio driver Conexant Cx20468
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-31530-1
right now u can download ur drivers here
plz vote any more problem reply
Mar 03, 2011 | Computers & Internet
354 people viewed this tip
David Payne
David Payne
