Tip & How-To about Computers & Internet
How to recover corrupted PowerPoint file using TEMP folder?
Today tip will help you to recover the unreadable and corrupted file of Microsoft PowerPoint. Normally PowerPoint open files can become corrupted when you are trying to save it or if you were working on it and your PowerPoint application or windows crashed due to power failure. Windows saves a duplicate copy of working file as a temporary version. There is no need to use any third party software to manage these types of corrupted files, because you can recover them from TEMP folder.
Follow the given steps to recover the corrupted files in MS PowerPoint:
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
First click on Start button then click on Search option to start your search process.
Here type the *.TMP in "All or part of the file name" box then choose the "Local Hard Drives" option in "Look in" box.
Now click on Search button to start the search process of temporary files on your system local drives.
After some time, windows locate the list to temporary files. Here arrange the all temp files as Date modified.
Now open the PowerPoint and try to open these temp files or double click on that file to run in PowerPoint
Computers & Internet Logo
powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Jul 27, 2015 | Microsoft PowerPoint 2003 for PC
How do I recover a corrupt PowerPoint 2013 presentation?
You can try:
PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files. This tool guarantees the compatibility with all available software configurations therefore PPT on repair of reinforced concrete structures works anywhere in the network.
For more information: https://www.pptrepairtoolbox.com/
Mar 02, 2015 | Microsoft Office Computers & Internet
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
how do i fix ppt file? Please help
Hello. There are different methods available to recover corrupted PowerPoint files.
Open presentation in MS Word document
and follow this steps:
- Open MS Word.
- Click on Open button of File menu.
- Select Files of type box and navigate to your corrupt file, Open it.
Also you can try Recovery Toolbox for PowerPoint https://powerpoint.recoverytoolbox.com/
More information see here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/677-how-to-recover-powerpoint-file
Feb 05, 2015 | Microsoft PowerPoint for PC
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
292 people viewed this tip
David Payne
David Payne
