Tip & How-To about KitchenAid KSRG25FKSS Side by Side Refrigerator
The ice maker is not working, but ice water dispenser operates
Try defrosting the fridge completely, this will tell you ifd the icemaker lines are frozen.
The ice maker is actuated by a solenoid.
To check if the lines are frozen , defrost the unit.
Check the water valve connected to the hose at the back of the unit.
The ice maker solenoid is tested by reading the ohms on solenoid with a multimeter.
Other faults can concern the impeller pump that is sending water to ice maker, that is tested by energizing the pump.
to disassemble the icemaker click the diagram below:
Click on picture above to open diagram.
Here more diagrams:
CABINET PARTS
CONTROL
More diagrams for your model.
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
the ice maker stopped working
is the thermostat working? try turning it up if you can,
as its getting colder out side the heating in the house is now running???
kind of like summer but hotter in doors!
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
JennAir JSD2789GES ice maker /water dispenser
if the water is stored in a container matrix in the fridge (to cool it down b4 dispensing) it may have frozen up. best give the unit a complete defrost to see if this is occuring, if so the thermistors may be faulty.
Jul 07, 2007 | Maytag MZD2665HE Side by Side Refrigerator
ice maker won't work
Check that lines are not frozen.
Check the inlet at the back of the fridge, ensure is not blocked.
Defrost unit completely to ensure it is not a frozen lines problem.
Check icemaker inlet valve, solenoid, and mechanics.
Here diagram and parts for your fridge's icemaker.
May 20, 2009 | KitchenAid Refrigerators
no water to door or icemaker on KSSS48DBW00
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 22, 2009 | KitchenAid (KSRD22FKST) Side by Side...
icemaker not filling with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Apr 01, 2009 | Maytag MZD2669KE Side by Side Refrigerator
3,259 people viewed this tip
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
