Tip & How-To about Computers & Internet
How to boost your computer performace w/o without installing any software
Right click my computer then properties, then advanced tab, performance settings then click for best performance then apply ok... finish
Computers & Internet Logo
i have a emachine e627 i got it in Dec of 2009 and a blue screen flashes up that says driver_trol_not_less_or_equal_ than windows try to restart again..
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab.
3. Under Performance, click Settings.
4. Click the Advanced tab.
5. Under Virtual Memory, click Change.
6. Click No paging file. Click OK, click OK, and then click OK.
7. Restart your computer.
8. Click Start, right-click My Computer, and then click Properties.
9. Click the Advanced tab.
10. Under Performance, click Settings.
11. Click the Advanced tab.
12. Under Virtual Memory, click Change.
13. Click System managed sized. Click OK, click OK, and then click OK.
14. Restart your computer.
Hope this works!
Jun 12, 2010 | Computers & Internet
i just set up a dell gx260 and is runing slow
Start Accessories System Tools Defrag, also, try right click my computer properties advanced performance ajust for best performance, then go to advanced tab and increase memory click set apply ok then do disk cleanup, and try a full system scan for viruses with you anti-virus software, then go to search and type adware find, delete, go to task manager, click processes look for adware in the name and end process untill you find and delete it
Jul 16, 2009 | Dell OptiPlex GX260 PC Desktop
DEP won't allow windows to open.
Right click on My Computer and select Properties.
Click on Advanced System Settings
Click on Advanced tab
Click on Settings button under Performance
Click on the "Data Execution Protection" tab
Select "Turn on DEP for essential Windows programs and services only"
Click on Apply and OK.
Mar 12, 2009 | E-Machines eMachines Desktop PC
Thumbnails not showing in Explorer in Windows Vista
In the Advanced System Properties when you right click on (My) Computer, you probably set the Performance Settings to "Adjust for best performance". In there you will see a Custom List of options and "Show thumbnails instead of icons" needs to be checked.
Jun 10, 2008 | Computers & Internet
Upgraded all hardware, installed all drivers, go to play a game that should work fine but system can't seem to handle it. screen starts to shutter. changed all settings to lowest so that it should provide better performance but has not worked. On paper I exceed all requirements but it does not play smoothly.
Offhand, what I would suggest is to tweak your OS for maximum performance (not necessarily faster but more efficient and stable). Things you can try are:
1. right click on "My Computer", click on "Properties";
2. click on "Advanced" tab, click on "Performance Settings' button, in "Visual Effects" tab, tick "Adjust for best performance", Apply;
3. in "Advanced" tab, tick both instances of "Programs", Apply;
4. click "Virtual memory" "Change" button, tick "Custom size" type in 2048 or whatever it is that is twice of your memory on both Initial and Maximum, click on "Set" button, OK. OK;
5. Goto Start, Run, next small window type "msconfig" less the quotes, OK;
6. in the "System Configuration Utility" window, "Startup" tab, un-check everything (except perhaps your anti-virus), Apply, OK;
7. Reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
157 people viewed this tip
David Payne
David Payne
