Tip & How-To about Plumbing
The Leak - How to Repair the Leaking Water Pipe
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Water is dripping constantly from the rag that you have wrapped around the pin hole in the water pipe. Let's see how easy it is to fix that dripping and give you peace of mind. With some of the fantastic improvements in plumbing fittings in the last few years, plumbing repair has been made very simple. Many leaks are caused by just a couple of things. The pin hole in the copper pipe that is caused by pitting inside the pipe. Usually this is caused by poor water quality. The inside of the pipe flakes off to cause a hole inside the pipe that eventually gets through to the outside. These often are given away by the green spot that usually is seen on the outside of the copper pipe first. This is caused by mineral left by the water evaporating off of the surface of the pipe. So in all reality there is a leak before there is a leak. The other main problem is the joining of two dissimilar types of pipes. Copper and PVC or Copper and Pex are two examples. The expansion rate of the two different types of materials is very different. This causes friction and constant movement where the two meet. This movement eventually will cause enough of a gap to allow the water to leak out.
Until recently there where many redneck fixes out there most involving garden hoses, inner tubes, hose clamps, epoxy, and many other creative fixes. I have seen way too many to describe all of them. Now there is a great way to fix those leaks with a simple push fitting. The new design of the push fitting allows for the pipe to be cut at the hole and then a coupling just pushed onto the pipe to fix the leak. The hardest part of the whole process is to get the pipe cut neatly. The same fitting can also be used to replace those pesky plastic to copper unions that always seem to give trouble. Joining different types of piping is no longer a problem.
By doing a quick search for push fitting you can find a number of different suppliers of this type of fitting. I have used a number of different ones and they all seem to work well. My preference is the brass types as they seem to be much more rugged in construction. The price of those fittings also reflects that. The most common that I have seen and used are the Sharkbite Brand. These are very good, are sold in many plumbing supply houses, and in Home Depot Stores. Other companies include Watts, Probite, Tectite, and Speedfit. I'm sure that I have left some out. These are some that I am familiar with and have used.
Bottom line is that it is now very easy for even a desk jockey to fix his own pipes. Go by the closet home improvement store on your way home. Pick up some of these fittings and impress the wife with talents that she did not know you had. You may even get brave and do that small plumbing project that she has been begging for. Now you can use these fittings to cut into that water line to run that new outside faucet or hookup that water filter yourself. With the push type fitting plumbing has been made easy enough for anyone to be able to do it.
Plumbing Logo
can you wrap tape around pipes
Yes, you can use heat tape on pipes UNLESS they are plastic or PEX. Copper lines - no problem.Heat tape is used to keep lines from freezing, and generally they do a good job at it, IF you get it wrapped around the part that usually freezes. BUT please understand the design purpose of heat tape before using! For example: My kitchen has an overhang that extends about four heet from the foundation that the water lines run through. In -30 F weather, my water lines will freeze up. I initially wrapped heat tape on the lines below the sink and still had freeze up. So I relocated the heat tape to the crawl space and wrapped the pipe as close to the foundation as I could. That solved the problem.
Nov 29, 2011 | Easy Heat Water Pipe Heating Cable
My Windstar has a pipe that comes out of the water pump and wraps around behind the intake. It has a hole and is leaking. Can this be soldered? What pipe is this?
Heater bypass. cannot be soldered/welded as it is aluminimum and under high heat and constant pressure when vehicle is running.
Jul 17, 2009 | 1999 Ford Windstar
resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
I have water leaking into the ref compartment from the freezer
I would get a pipe cleaner or wire and clean out the rest of the drain hose. also use HOT water down the drain. untill all the water drain thru the hose.
after you get it clear run a wire down the drain and wrap it around the heater .. heat from the wire will keep it clear of ice..
Dec 21, 2008 | Kenmore Refrigerators
403 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
