Tip & How-To about Televison & Video
How to Wire a Flat Panel Television with no wires showing
  1. Place all the components, TV, speakers, etc. where you want them. Don't worry yet about how to wire them.
  2. You may want to turn all equipment sideways on the shelves so you can get to the connections in the back.
  3. Plug in all the power cords into a power strip, but don't turn on the strip until you are all done.
  4. Learn to differentiate audio and video. Video connections are often yellow, audio connections are often Red and White, but newer systems can have more varieties. You'll need to make sure the color you are plugging in is the same for both ends of the cable.
  5. Start wiring all the cables. You can see that all the cables and connections are clearly labeled and color-coded.
  6. Use the concept of 'signal path' to connect the necessary OUT's to IN's. Cables are needed to give the signal a path to travel from one piece of equipment to another. OUT of the antenna, IN to the VCR. OUTof the DVD player, IN to the TV. OUT of the receiver, IN to the speakers etc.
  7. Follow this guideline when hooking up equipment:
    1. The wall (cable/antennae/satelite)
    2. Things that send out signals (TiVo/cable box/set-top box)
    3. Things that record (VCR/DVD Recorder/Computer)
    4. Things that play only (VCR/DVD/Receiver)
    5. Things that display (TV/Monitor)
  8. Turn everything on. If necessary, switch channels and settings to match the labels on the connections you've just made. Enjoy!
Televison & Video Logo
i have connected my dv720 i have no sound and a blue wire a blue and white wire and a beown wire not doing anything should these be connected to something if so what?
The blue/white wire is amplifier remote turn on, so if don't have an amplifier you don't need to worry about it. Just cap it off so it doesn't short to anything. I'm not completely sure, but I think the brown wire may be a phone mute wire. You don't necessarily need it either. If you have no sound, you may want to check your speakers and speaker wires for any shorts, grounds or bare spots.
Nov 07, 2012 | Car Audio & Video
No sound when HLN5065WX/XAA is turned ON. No sound from the TV speakers or from my home entertainment system. Does the TV have a sound card? Can it be replaced? Any ideas. Thanks
f you are using Cable, DSS, or FIOS, etc, check the audio output from the box in Audio settings menu. make sure you don't have "Bitstream" selected most common audio connections are PCM (digital optical) Coaxial (single audio RCA) or HDMI with audio passthru. If those settings are correct, check the Audio settings on the TV and on the AV equipments Audio input. If you still have an issue, post a reply/comment listing all your equipment's model #'s and I can help you further.
Jun 14, 2011 | Samsung Televison & Video
toshiba 32a42. power light flashing, tv will not turn on. tried unplugging for about two hours and that did nothing.
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place.......
Apr 14, 2011 | Toshiba 32A42 32" TV
have 2 Behringer Eurolive B 215 Speakers and the 15" woofer have no sound coming out only sound thats coming out is from the horns
These have a crossover inside as well as a fuse. If it is blown the link is gone and only the horns will work.
May 13, 2010 | Behringer Eurolive B212A Speaker
blown tweeters on pair of The Amazing Alphas
check on radio shack maybe there got something that fits your necesities
Feb 06, 2010 | Audio Players & Recorders
403 people viewed this tip
Top Televison & Video Experts
