Tip & How-To about Computers & Internet
Basic Laptop and Desktop PC preventive mainance tip.
I strongly believe the #1 issue 'other than physical damage' that causes issues with laptops and desktop PC's is not keeping them cleaned and blown out of dust/debris. Just like changing the oil on a vehicle regularly greatly increases the life of an engine. Many issues with PC's can be so avoidable by a less than $5.00 'non flammable' can of air. Desktops are worse than laptops of course since they reside of desk cabinets or on the floor. It takes less than 10 minutes and even less time for a laptop to 'power the PC down, remove the power cord' and then blow out the power supply and its fan or on a laptop 'usually the back or side of the unit' where it's pulling in the cool air. If you have the courage to pull the cover off the desktop, 'again remove power' you will see the build up of dust inside the cabinet. Blow all this dust out if you can and this will help increase the longevity of your laptop or PC. Think of it as an oil change for your PC.
Blessings always,
A/V Media Tech Guy
Computers & Internet Logo
my acer aspire 8930 9600m gt gpu keeps overheating what is the problem
Gaming (and graphics application) consumes more CPU/ Processor resources and due to the heavy processing the PC (CPU & GPU) heatup. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ GPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Apr 16, 2011 | Acer Aspire AS5252V333 Notebook
hi i keep losing signals in my Nokia e5... will you please provide the solution to fix this problem in my phone.
You need to reset the mobile back to its factory settings. But before you do this please make sure that you create a backup of your mobile to your Laptop or desktop using Nokia PC suite.
After you have done the factory reset, please update the phone to the latest update. Once this has been completed, you may restore the backup file using the same Nokia PC suite.
The issue can be due to software issue. Moreover I am not sure if there has been any physical damage on your phone that wold have caused this issue. But if that is the reason then you will need to go to your nearest Nokia store to get the phone have a check up .
Mar 29, 2011 | Nokia E5 Cell Phone
Screen problems
Hi:
The next time your laptop screen is messing up, try to hook the laptop up to an external monitor. If the picture is bad on the monitor too, you have a laptop video card issue. If the picture is good on the external monitor, then you have a problem with your laptop LCD/ inverter.
Nov 11, 2009 | Dell Computers & Internet
Dell Dimension 8300 Windows XP won't boot, just blank screen
Start by taking the motherboard battery out for a minute and cleaning and reseating the ram (memory), then try to reboot.
Post back foe more advice if needed.
Good luck
Jun 15, 2009 | Dell Dimension 8300 PC Desktop
acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do ....
First thing to try is to reseat the RAM on the laptop, as it could have came lose a little causing this non boot problem.
I might even be something wrong with the BIOS. You can try resetting the BIOS
Check if the laptop fans are working. As a overheating CPU or GPU can cause this problem as well.
Aug 14, 2008 | Computers & Internet
109 people viewed this tip
David Payne
David Payne
