Tip & How-To about Plumbing
Mansfeild flush handles fit all.
Mansfeilds #35,40 and 41 plastic flush handles can be heated and formed to the shape you want.
Plumbing Logo
replace 2007 Oddysey tailgate light assembly
To Replace a Tailgate: Tools needed for the replacement:- Star shaped sockets- Flathead Screwdriver- Long Nose Pliers- Shop Light- Dremel w/ disc cutter for plastics, Remove the 2 outer long star shaped screws: Close Tailgate and pull down and out the handle bezel. The bezel itself its being held by 2 plastic anchors. To remove the handle from the tailgate we need to open it. Pull the linkage from both sides inward and the tailgate should open. Remove the 3 large star shaped screws-------------------------------------------------------------------------------------------
Tacho Pro 2008
Mar 18, 2013 | 2007 Honda Odyssey
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
how do you replace drives side exeior door handel for 95geoprizm
1) Remove the plug inside the interior armrest and remove phillips screw.
2) Remove armrest and two screws that hold door panel to door frame.
3) Pop the outer cover off the interior door handle.
4) Remove the interior lock knob and remove door panel by popping out tabs connected to door frame and lifting up off of window ledge.
5) Remove the two nuts holding exterior handle in place.
6) Disconnect the L shaped linkage from the handle. The trick to getting the L shaped linkage into the new handle is to feed L shaped metal pole through hole in door where exterior handle was, leaving the lower end of this linkage in its slot.
7) Feed the end of L shaped pole through the plastic 'hinge' in new handle by folding the hinge over and pushing the end of the L through both sides of the plastic hinge at once. slide the lower loop of the plastic hinge down the L shaped pole to secure pole to handle.
8) Place new handle into door and reverse the process to reinstall interior panel.
Hope this helps Tim
Apr 17, 2011 | 1995 Geo Prizm
basement toilet won't flush. water fills the bowl and tank fills back up...but toilet doesn't flush
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Sep 07, 2009 | Home
314 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
