Tip & How-To about Video Game Consoles & Games
Playstation wont read disks or gives disk error message
Hi, if any console is giving you this message or something similar then this would mean one of a couple of things that could be wrong.
The first thing you should try is go out and buy a cd lense cleaning kit, you can buy these from most computer hardware stores, dont buy the cheapest one their as they tend not to work as good.
Once you have this cd put it onto your console and then let it clean the cd lense this should then solve your problem.
If after doing this you still have the problem then try another game in the console to ensure that the disk your using isnt bad, if it still gives the same message then this would indicate that the laser needs replacing or it could also mean the console has over heated.
Its not possible to fit a new laser yourself as you need special equipment to set the new laser up.
Remember never use any console whilst it is on carpet or on top of anything like dvd player or sky/cable box as any of these can cause it to over heat very quickly, make sure air vents are clean and free from dust to ensure good circulation inside the console as build up of dust can cause it to over heat
Video Game Consoles & Games Logo
Track will not go. Gives E3 in time slot.
Depending on the manufacturer, an Error 3 message can mean one of many things.
Some machines do have an auto stop feature when they detect something wrong on the Main Board but again it can very well be something completely different.
We would be happy to help you figure this thing out, you can call us 888-713-2880 or chat with us online at www.sportsmith.net
Aug 30, 2015 | Exercise & Fitness
x box 360 is scratching discs does it mean some thing wrong
It sounds like you may have something stuck inside the console. It may also be that something is off track inside of the console. If little kids are in the area where this console is located there very well might be something stuck inside. Check for rattles in the console. Hope this helps.
Nov 24, 2010 | Microsoft Xbox 360 Console
my xbox will not give a signal to a tv or monitor...any suggestions?
There are a couple of things that come to mind, none of them too good.
For starters, your problem could be the cables are bad. Considering you're using two separate cables, that's unlikely.
The most probable thing is that there's a problem with the 360's hardware itself, whether it be the port or something on the board itself. Either way, you're going to have to ship it out or find someone who knows the hardware well.
Good Luck :)
Dec 31, 2009 | Microsoft Xbox 360 Console
Same thing
Honestly, the best thing to do if there is a problem after getting the system back and it has the same problem is to call them immediately. That way, if they did something wrong in the repair process they will be willing to fix it for free rather than charge you a repair fee.
If you want more information, can you post more about what error message you get and such?
Jul 17, 2009 | Microsoft Xbox 360 Console
can't reinstall
Is the fatal error during installation or post installation? Also what do you mean something always goes wrong, if you can give more information we maybe able to help.
Jul 07, 2007 | Acer Aspire 3000 Notebook
213 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
