Tip & How-To about Car Audio & Video
Air space required for 15" subwoofer and box specs
Regardless of your wattage rating on your sub woofer, sub woofers differ in only one way. You get an "Open Air" and a "Closed air" Sub woofer, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" Sub woofer, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.
Regarding the "Closed air" sub woofers, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.
On a 15 inch Sub woofer ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 400mm high, x 400mm wide, x 400mm deep.
Enjoy!
Car Audio & Video Logo
i got vauxhall astra 1.6 and planning to put 1800w bass sub woofer. Can I do that, does astra can handle that.
If it is clean power it can handle it. Bad power causes distortion and DC output. That is what kills the sub woofer. The going rate for quality / good wattage is a dollar per watt. If you are not spending that much, then it is bad power.
Nov 01, 2013 | Cars & Trucks
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
7,431 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
