Tip & How-To about NetGear WGR614 Wireless Router
How to set up wireless connection or security feature on Netgear WGR614 ?
Following steps will be useful:-
a)Connect the router to the laptop or use any pc which is connected to the router.
b)In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
c)When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
d)Select Wireless Settings from the Setup menu in the left-hand navigation bar.
e)ssid:-any name , channel:-11 , mode:-g and b
f)Under Security Options, select WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
For WEP:-
authentication type should be automatic and encryption strength should be 64-bit.
passphrase:-leave that blank and only select key1 from the list of four keys and in the key1 box type your telephone no. or enter 10 hexadecimal digits of your choice and apply the setting's.
The number in the key1 box will act as the password to connect to the wireless.
For wpa-psk:-
In the passphrase box enter any password of your own choice between 8 to 63 characters which will be password to connect to the wireless and apply the setting's.
NetGear WGR614 Wireless Router Logo
linksys sd208 reset
The reset button is usually at the back of the router. If you are unable to locate it you can reset it using a web based set-up page. Make sure you connect your router to a PC using wired connection and perform the following steps:
Step 1:
Launch a web browser like Internet Explorer.
Step 2:
In the Address bar, enter "192.168.1.1" as the router's default IP address then press [Enter]. If this doesn't work or if the IP address of your router has been changed, enter it instead.
Step 3:
Enter "admin" in the Password field then leave the User name blank. If you have set up a User name and Password for your Linksys router before, enter your personalized credentials instead.
QUICK TIP: For Linksys Smart Wi-Fi Routers, you can enter "http://myrouter.local" on the Address bar to access its web-based setup page.
The router's web-based setup page should now appear from here you can reset the router.
for more info browse this link: http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=3676
Sep 19, 2013 | Computers & Internet
how to connect via wfi to a router
if you're using windows 7 then search available wi-fi from bottom right task bar.
if wi-fi is visible then click to connect it.
if you want to set up your own router then goto web browser and enter following into URL bar
192.168.1.1
Jan 23, 2013 | Computers & Internet
need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I can no longer connect to my linksys profile. I use the WRT54G router. I reset the router password but when I try to log on to the profile it asks me setup questions and even when I put in my password it will not connect.I reset the router to default settings and have gone through a number of steps but nothing has worked.
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter “admin” as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router.
Through the Web Administration Pages The second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults
Jun 08, 2010 | Linksys Wireless-G WRT54G Router
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 14, 2010 | HP Pavilion dv6000z PC Notebook
1,061 people viewed this tip
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
