Tip & How-To about Video Game Consoles & Games
How to boost PSP signal..
The little antenna is on the power light side.. when trying to get a better signal, make sure ur hand isnt over the power light side of the psp.. it should boost the signal... or make sure the power light side faces the router.. that should boost it significantly.
Video Game Consoles & Games Logo
Problem with HDTV POWERED FUTURA ANTENNA 24769. Amp light goes out when connecting cable to amp. No difference in picture quality or quantity.
Well I think you are trying get a better picture not a better stereo signal unless TV tuner is in AMP. If not try connecting it to TV dirctly but first inquire manual to make sure that is how it is sappose to be connected. But if I was a betting man thats probley what it is, but not sure what equipment your working with besides the info on atenna that you sent.. Good Luck !
Apr 15, 2014 | GE 24769 Futura HDTV Indoor/Outdoor...
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
my 97' s-10 has a delco stero and the signal keeps going in and out like the ant. is not pluged in all the way, but i took the dash loose and puled out the unit and made sure its in all the way. it acts like the signal its getting isnt strong enough and its stuck on one station untill it comes on then i can change the ststion,and when i get close to a large metal structor or bridge it wants to come in more but after passing it goes back to noise. is this something i can fix or is the stero bad on the inside ?
Try a different antenna. Usualy a replacement antenna is only about 6 dollars. Try this first to make sure it is not the antenna. Even cheaper if you have at least 6 to 10 feet of wire splice one end and stick into the the antenna hole of the stereo. Extend the rest of the wire and see if signal is better. If the signal is better then the antenna needs to be replaced. If it doesn't get better, then the stereo needs to be worked on.
The only problem with that is that any delco service center will start at about $75 to look at the stereo. Replacing may be cheaper in the long run.
Nov 18, 2009 | Car Audio & Video
Green light but nothing comes on
It seems that inside your PSP the LCD Screen Connection cable (The broad One) which is connected to the motherboard is being loose contact so if you can open the PSP try it by re-fixing the cable again otherwise you better go for a technician who will do the same job for you.
Sep 10, 2008 | Sony PlayStation Portable (PSP) Console
Antenna broke and I replaced it
If your not sure what to do at this point you probably should stop right here, however if your bold enough to try this, remove the back cover, I believe there are 6 (six) screws in total, there is also a small metal contact that touches the main circuit board on the back side, that also connects to the antenna, most often a springy piece of gold plated metal attached to a solid threaded nut, where the antenna is attached that fits snugly into the back cover of the phone when the cover is installed the nut is secured and won't fall out. This contact could be on the nut or on the main board if you bent it out a bit to make better contact, you will most likely fix your phone. Cheers!
Mar 03, 2008 | Cell Phones
387 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
