Tip & How-To about Vacuums
Re use vacume bag trick
Take out your vac bag and if you have no others u can snip off the bottom where it is folded over dump out the junk flaten out the bag on the table fold the end back up and staple it with a normal stapler and that,s it.
Vacuums Logo
How do I clean out nutone cv556 filter bag?
There are 3 options: 1) Use another vacuum like a shop vac to clean the filter bag while in place. 2) Wrap a trash bag around the bottom of the canister with the dirt can removed. Tighten the trash bag around the metal can and smack or shake the filter bag. This will prevent dust from escaping into the air and on you. 3) Grab the filter bag towards the top where it locks into the can. Pull the filter bag towards the center of the can to fold it into a C-shape. This can be hard to do, so do not be afraid to pull. Once folded into the C-shape, the bag should come out easily. Take the bag outside to shake off any debris. To put back in place, use the C-shape method again, and fold out to form a full circle. DO NOT wash the bags out with water.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Central Vacuum Intercom and Whole House Audio Systems
May 22, 2014 | Broan-NuTone CV556 Cyclonic Bagless...
I have a Kirby Heritage 84. Great condition except the part that connects the innerbag is missing. I don't even know what it is called. I can open the vacuum cleaner bottom and see that the part is missing. It should be oval where it connects to the vacuum and then extend into the cloth bag. PLEASE HELP!
The Heritage 84 had two different bag assemblies available. One is a dump-out bag. The dirt simply dumps through the bottom. The other is the bagged style which has a full length zipper to open it. Inside it should contain a "bag fill tube", and a top adapter to attach the bag onto. The oval fill tube is no longer available, but a round tube can be installed with a bit of efort.
Dec 12, 2010 | Kirby Heritage II Vacuum
the bag indicator shows full but the bag is empty
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
Jan 28, 2010 | Hoover Vacuums
Kenmoore Intellivac w direct drive suddenly started making internal sound like something was stuck. Hose is clear, and sound is made when hose is detached from main unit. Vacuum sounds find at lower pressure, only makes sound with bag door closed and/or placing my hand over the end of hose.
Shut off the vac and open container and remove the bag. Try dropping a coin into the hose, then raise up to see if it falls thru to the bag area. If it does check the throat of the vac where the dirt is sucked upward to dump into the bag itself.
Sep 05, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
May 09, 2009 | Shop Vac Vacuums
207 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
