Tip & How-To about Televison & Video
How to program your Dish Network remote to your tv
Find your Codes for your devices here first: http://www.dishnetwork.com/customerService/troubleshooting/nhagent/default.aspx
The follow these directions:
OK, I understand that you need help programming your remote control to a TV or other equipment.
Note: After this procedure is started, if a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
Step-by-Step Procedure // Step 1 of 6
Click on the following link to find the remote codes for your brand of TV, VCR, or other equipment. Note that codes for each TV brand depend on the remote type.
Step 2 of 6
Press and hold the correct Mode (TV, VCR, or AUX) button for about six seconds until all mode button backlights come on, then release.
Step 3 of 6
Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
For AUX mode ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device.
Step 4 of 6
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Step 5 of 6
To verify the code works, press the mode button. Try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Step 6 of 6
If the remote still does not operate the device, perform the Power Scan.
If the remote still doesn't operate equipment, it may not be compatible with that equipment.
Televison & Video Logo
need the codes to program dishnetwork remote to work the zenith converter box
Hey there marlastewart!
I can definitely assist you in getting the codes for that. You can view this link http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx to search for codes based on the equipment and brand.
If none of the codes work let me know and I can try further troubleshooting with the remote!
Tommy Faust
DISH Internet Response Team
Jan 05, 2012 | DISH Network IR Remote Control
e7 code what to do ?
Before calling service technician, call Bosch. 800-642-3111
E7 is not shown as common error code.
Error codes are considered start-point for troubleshooting.
Open following links for general Bosch troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Common error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Service bulletins for reading how to fix tankless yourself:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/ServiceBulletins/tabid/1300/Default.aspx
Aug 27, 2011 | Bosch AquaStar 2400ES-NG
I have a simple gray remote and I lost code manuel for it and I need codes for my dish network box and codes for my 65 inch mitsubishi
Hello, I am sure that you have resolved this already, but here are some steps for you. Just follow the link provided below and it will get everything working for you. Hope it helps.
http://www.dishnetwork.com/SupportSection/remote-setup
and you can also download manuals for your equipment here:
http://www.dishnetwork.com/support/documents/receivers/default.aspx
Becki Barned
DISH Network Customer Service
Jan 02, 2011 | GE JASRM24912 Remote Control
325 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
