Tip & How-To about Garden
Precautions to take when storing 2 cycle lawn equipment
Any time a weed wacker, chain saw, snowblower, leaf blower, or any 2 cycle machine must be stored for a period of time exceeding 6 months the gasoline must be removed completely from the gas tank and carburator. To do this simply run the engine until it runs out of gas then proceed to choke the carburetor and restart until no start up ocurrs this removes all fuel preventing the carburator from gumming up. This will allow you to store the unit for long periods of time without the worry of having to disassemble the carb. and clean next time it must be used.
Garden Logo
handle on UPVC door needs replacing. Have been quoted 230 Euro. Is this a DIY job?
Dont advise DIY on chain saws they are small and pain in the *** to work on every time I endulge seems something else goes wrong with it, I dont mind the bigger things(lawn mower engines etc.) but not weed wackers, chain saws, or leaf blowers.
Aug 12, 2010 | Garden
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
191 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
