Tip & How-To about Computers & Internet
How to increase the life of your laptop battery
This tip is generally to be used with when you first buy a new laptop, or a new battery.
The trick here is letting the battery charge and then die.
So here is what to do
  1. Plug everything in and begin charging the laptop
  2. When it gets full, take the power out and let it drain using a high performance setting
  3. Once its dead flat, re charge it
  4. Once its fully charged, take the power out and use the default power settings (The automatic setting when you unplug the AC)
  5. Once its flat, charge it again
  6. Once its fully charged, Take the power out and set it to your personal settings you want when there is no AC connected.
Once these steps are done, your battery will 'learn' how much to charge and how to discharge, giving you a longer lasting battery.
Another handy tip is if your going to be using AC power a lot, take the battery out when you do this. And also when using a battery let it deplete and then recharge to keep it in top shape
If you are having additional problems, want more tips or need to speak to me on any other computer related matters, please don't hesitate to contact me on FixYa!
Have a nice day
Tim Goulding
ICT Technician
Computers & Internet Logo
Why does my battery not hold its charge
More than likely, like all batteries, it has outlived its usefulness - unless its relatively new or unless you are one of those folks whose daily cell phone usage exceeds the hours of sleep you get each night. But generally, when a battery of any kind - car included- won't any longer hold its charge, it is dead or dying, or perhaps the charger is defective in some way. Call the manufacturer or the store where you purchased it.
Aug 14, 2016 | Cell Phones
I have a Icraig wireless touch screen tablet model number cmp773-GD , and it won't turn on or charge. Why?
If u just got it return it. your battery is died need new one.tip to make battery last longer. when u get a new battery by itself or it is part of something like a cell phone. do not charge most have half power right out of the box. use battery until it is 100% died.then charge it until full don't over charge. it is a trick to make your battery last long when it has a full charge. never leave battery charging overnight if done to much it makes the battery weak and wont hold charge for long. never leave charging cord plugged in when its not in use. when it is power from the socket is still flowing in the charger which is slowly frying it. that why most people go though up to 4 chargers for each device. i hope this helps have a sweet one!!
Aug 12, 2015 | Tablets & eReaders
what will happen if the battery in your laptop is not fully charging
That would mean your battery is dying and you need to go buy a new battery for your laptop. You can buy new batterys for around $40
Find a store that sells laptop parts or go online look on amazon or next tag also when you get your new battery plugin your laptop charge your new battery so it has a full charge.Then when it is done charging unplug it and use the battery until it dies, then plug it in again to recharge it never leave it plugged in if it is fully charged for long periods.if you are using your laptop at home you can pull out the battery and use it when its plugged into the wall this will help to extend your battery life just make sure you have a fully charged battery before leaving your house. always unplug your your laptop when its is fully charged this will also extend your battery life for along time
Sep 26, 2012 | HEWLETT-PACKARD Hewlett Packard Battery...
i can charge my acer for days and the battery will die within min
The Battery is bad and so its not retaining charge, You may need to get a new battery and from an authorised reseller.
Dec 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Battery back up is limited to 1 hour only
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
Jan 16, 2008 | Acer Aspire 3680 Laptop
143 people viewed this tip
David Payne
David Payne
