Tip & How-To about Samsung DLP HL-P5663W 56" TV
After Replacing Lamp and TV still does not Work
If you have replaced Lamp and TV will still not come on It will be your Ballast Board. Ballast is What turns Lamp on, Again Always Make sure Fans are running if Fans are OK and New Lamp will still not come on it will be the Ballast Board.
Samsung DLP HL-P5663W 56" TV Logo
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front button flashes. Any suggestions?
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please help..
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV keeps turning itself off, how to stop this? Thank you
CK all of your Fans and you may have Bad Ballast Board. But Start with fans if they stop running set will turn off also go to Encompas Parts online look up your Model Number or call them 1-80-638-3328 and you could have defective Lamp if Lamp has never been replaced and all fans are running then its the Lamp! If Lamp does not come on its the Ballast or Bad Fans.
Nov 23, 2009 | Samsung HL-S5087W DLP TV
My Toshiba DLP Projection TV (52HM84) will not always power up. It sometiems goes through five of six retries. Is it the paower supply or maybe a related part (capicitor) ?
Pull back make sure Fans are clean ,But if you have never replace Lamp ,Lamp needs to be replace call Mats 1-800-628-1118 Rember also Ballast board is what turns Lamp on For Ballast board call Encompass 1-800-638-3328
Sep 26, 2009 | Televison & Video
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
1,505 people viewed this tip
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
