Tip & How-To about Samsung DLP HL-P5663W 56" TV
DLP TVs Lamps and Defective Lamp Fans
Most people Fail to understand that the Lamps in the DLPs are only desiged to Last for 5,000 up to 8,000 Hours so Meaning that every hour you watch TV the Lamp dies some even go out quicker then others! So before replacing Lamp always make sure your Fans are running if Lamp Fan is defective Lamp will not light because it is what Cools Lamp while it is on their for set will not come on.
Samsung DLP HL-P5663W 56" TV Logo
MY TV ACTS LIKE IT WANTS TO COME ON BUT CLICKS BACK OFF
Has the Lamp ever been replaced? Lamps only last between 5,000-8,000 playing hours.
May 30, 2011 | Samsung DLP HL-P5663W 56" TV
replaced the optical block a few years ago to correct the yellowish hue problem. Recently I had to replace the lamp. I had bought one new about 2 years ago. I put the lamp in and the TV is much dimmer than before, can hardly see during the day. Does a lamp go bad after a number of years? DO i need a new lamp or is there an something I am overlooking? I have also reset the defaults and cycled the power.
Lamps only last Between 5,000 hours some last 8,000 hours
So what that means For Every hour TV is Playing it is burning up hrs of lamp. These sets are not like projection that you can run day and night .
Most Lamps need replacing every 2 yrs Depending on how many hours you watch TV?
It could be that the Lamp you have is defective ,Mats has Lamps for $99.00 1-800-628-1118
Get New Lamp then see if that corrects the problem.
Sep 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Does a Zenith Z44SZ80 DLP lamp quit after a set amout of hours
Lamps are only design to play 5,000-8,000 HRs you cannot leave them on day&night like projection ,they will burn Lamp out quick. For New Lamp go to E-Bay 85.00 and up.
Sep 16, 2009 | Zenith Z52SZ80 TV
1,362 people viewed this tip
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
