Tip & How-To about Office Equipment & Supplies
Setting up (HP Jetdirect print server) Printers on a network
To install the HP printers with a built-in Jetdirect print server as a network printer you need to do the following -
1. Configure the HP's IP address using the printer's Menu options.
Enable the Network and configure the Network settings so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100, set the Subnet Mask to 255.255.255.0
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router with a LAN cable and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to install the printer driver and configure the TCP/IP port for HP printer the same way on every computer on your network.
Now any computer on your network can print to this printer.
For detailed instructions on configuring the Jetdirect card, go to this WEB site.
http://printertechs.com/tech/tutorials/networking/networking3.php
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc. This example is for a network HP Laserjet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following - 1. Open the printer?s menu and enable the Network Card ? these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer?s network configuration accordingly. 2. Install the HP printer driver on your computer/s using the LPT printer port. 3. Connect the printer with a LAN cable to the network hub/router. 4. Click on Printers and Faxes - right click on the HP printer and click on Properties. 5. Click on Ports and click on Add Port. 6. In available ports - click on Standard TCP/IP Port and then Configure port. 7. Tick the IP box and type in the IP address of the HP's printer IP address. 8. Click OK and tick Enable bi-directional support and then OK Install the HP printer driver on every computer on your network and configure the printer?s TCP/IP port as previously detailed. Do a test print page to check the printer. You can now print from any computer on your network.
Hello Geekman: Thanks for your help. The printer requires an admin key and no one seems to know it. I think once I'm in there, I can find the static ip address (I hope). I cannot find it anywhere else. Any suggestions on how to either get it or just reset the printer?
Dec 06, 2009 | Computers & Internet
set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
how to enter an IP address on a hp2035n
Jul 17, 2012 | HP P2035N LaserJet Monochrome Printer
9,007 people viewed this tip
k24674
