Tip & How-To about Office Equipment & Supplies
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
I have just purchased a Belkin N600 modem router. I have attached my Canon i850 printer to the USB port on the router but I cannot print. The green USB LED is not illuminated. Can you help, please? I am using Windows 7
I think you need to connect your printer to the router using an ethernet cable and not a USB cable. Ethernet cables are plug-and-play cables and doesn't require you to install a software. If you really need to connect your printer using a USB cable, you need to connect it to your PC so that the PC will run the installation wizard to install the USB cable. Of course the router cannot run installation wizard to the printer or the printer cannot run installation wizard to the router.
Sep 11, 2011 | Belkin Play N600 Wireless Dual Band Router...
DIR-615 wireless router not installing
You setup the router with the Ethernet cable always plugged in.. UNTIL you are finished configuring through the Ethernet cable via your browser. Once WiFi SSID & passwords WEP/WAP has been finished, AND you had another WiFi card in that PC the Ethernet cable was also connected to... well, THEN, I guess THEN, you may be able to disconnect the router from PC & then connect it again Wirelessly. But whats the point? But until then you won't find your router ON the Ethernet port, it would then be trough the WiFi adapter.. and that would have to be activated to work. Hope this clears things up
Feb 02, 2010 | D-Link DIR-615 Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
can't connect WGPS606 wireless printer server to cable router
suggest plugging print server directly into p.c via blue ethernet cable during setup. Then run setup program and then pick an ip address that works with your router (in same network ip range of router) that does not clash . I would use print server as a switch if it is close to the router by ethernet cable between router and wireless print server. Then both should work
Wireless to server and other wired computers as well .
Feb 06, 2018 | NetGear WGPS606 (WGPS606NAR) Print Server
1,985 people viewed this tip
k24674
Marvin
Marvin
