Tip & How-To about Computers & Internet
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
Computers & Internet Logo
how do I password reset
Hi Kim,
If you are unable to access the setup page of the router because you have lost or forgotten the username / password combination of the router, you will not be able to do so without setting the device to the factory condition. This means that any special settings that have been set will be lost. Before explaining the simple procedure to perform the reset - you may want to try accessing the setup page with the factory defaults:
Point or click your browser to http://192.168.1.1. If you haven't changed the default, this should bring you to the setup page. Otherwise, input the router address (if known). At the promt for the username and password, enter "admin" for both (no quotes) and click on the "Login" button. If you are not allowed into the router setup or do not know the setup page address folow these steps:
Note: Prior to connecting the router, be sure to power off your computer, DSL/Cable modem, and the router. You should setup the router with a wired connection first before attempting to setup any wireless connection.
Since your router has been previously configured, you should start from scratch by disconnecting all cables - except for the power cord. Then, reset the router by holding in the reset button at the back of the router for 10 seconds while it is plugged in and powered ON. Allow the router to sit undisturbed for a minute and then disconnect the power cord from the router. The router is now in the factory state and can be configured as described below:
Step 1 Connect one end of a network cable to the WAN port of the router and connect the other end of the cable to the DSL/Cable modem.
Step 2 With another network cable, connect one end of the cable to your computer's network card and connect the other end to one of the LAN (Ethernet) ports of the router.
Step 3 Power on the DSL/Cable modem and wait for the lights on the modem to settle down.
Step 4 Power on the router by connecting one end of the supplied power adapter to the power jack of the router and connecting the other end to an electrical outlet.
Step 5 Power on your computer.
Step 6 Make sure the WAN, WLAN, and the LAN port that the computer is connected to are lit. If not try the above steps again.
Follow the configuration as described in the manual linked here.
I hope this helps & good luck!
Mar 22, 2013 | Airlink AR430W Wireless Router
i have nokia siemen 1600 router ,,,nd someone set a password on admin,,,,i want to reset it...how is it possible,,,,tell me.....gurbax_cool@yahoo.com
The default userid and password is admin
if it doesn't works then follow the below steps as follows,
1.you need to reset the router
2.press and hold the switch at the back or connect through lan cable
Regards,
Ayyasam
Mar 04, 2010 | Computers & Internet
i have cricket broadband wireless internet, how do i set up my belkin wireless router to it so i can send out a internet signal to another source?
You cna get the router manual on the below link free link
http://dl.owneriq.net/8/81c69071-e6b4-da74-6921-04cb37aa97a5.pdf
Also you can follow the below steps to set it up
Let me know if this will help
Regards
Dec 04, 2009 | Computers & Internet
how do you hook up a dynex 802.11g wireless router
To setup your Dynex router you can follow the below steps
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.0.1 and then type the username as "admin" and the password is blank so leave the password box as blank
  5. You need to set it up as per your internet service provider if you do not have any fixed IP address provided by ISP then select dynamic IP address and then click on clone mac address after saving these settings on the router setup page you can check if you are able to access internet then you can do the wireless settings
  6. Once the router setup page is open you can confugure the router easily without the CD setup.
  7. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  8. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  9. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  10. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  11. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Dec 03, 2009 | Computers & Internet
router cable problem
replace the USB cable to ethernet cable follow this instruction below
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Feb 17, 2009 | NetGear RangeMax WPN824 Wireless Router...
538 people viewed this tip
David Payne
David Payne
