Tip & How-To about Computers & Internet
UPS - Battery Fault
UNINTERRUPTABLE POWER SUPPLY
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault. A faulty charging circuit will not charge the batteries and will also cause a fault condition.
Lower powered and cheaper type UPS are switch over types, when the mains supply fails, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power to the computer and peripherals. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
NOTE the power waveform from these UPS is a pseudo sine wave (i.e. not a true sine wave).
The true UPS types are usually the higher KVA units (over 1500 VA) that supply continuous mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power to the computer equipment, therefore there is no switch over time lag when the mains supply fails.
Computers & Internet Logo
my ups is not working
Batteries in the UPS will last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. Solution : replace the batteries
Nov 26, 2010 | APC Back-UPS CS 500VA UPS System
Uninterruptible Power Supply Faults
There is another condition that will produce the red light alarm. This occurs when the battery voltage exceeds 14.57 volts. There seems to be no fix for this condition.
Dec 06, 2009 | Opti - UPS ES800C 800VA 480W 1050 JOULES...
u p s by pass l e d flashing light
Nov 29, 2009 | Liebert (PS2200RT2230) UPS System
when ups is on it willgo to falt mode we have conected in tv
I assue you connected the UPS to a TV to test the UPS unit.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault. A faulty charging circuit will not charge batteries and will cause a fault condition.
These lower powered and cheaper type UPS are switch over types, when the mains supply fail, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
Nov 18, 2009 | Battery Basics Computers & Internet
hi in my apc es 500 the amber and green light is alternatively flashing and my ups is not working on battery power it is shutting down automatically plz help
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
Nov 12, 2009 | APC Computers & Internet
3,808 people viewed this tip
Alun Cox
