Tip & How-To about Computers & Internet
What do i need in a new computer? (Desktops and Laptops)
The basic answer is simple, you need a computer that provides your needs. When looking for a computer, there are a lot of factors to consider and ill look at them with you
First off
Space:
People often don't consider this one. You need a computer in a defined space, if its too big then its not ideal for you to use. And you also must factor in your additional items like speakers, printers, work space and so on. Lay out what you have and from there work out a practical size for your computer or laptop
Laptop VS Desktop. What do i go with?
This is a very debatable question many people have when deciding. Many factors need to be assessed before asking this question, here are the most common ones you should ask
Am i a mobile person?
This means that you work or go places quite often, like for example a teacher or a traveler. If you answered yes, a laptop would be your best option if you need frequent access to a machine, but if you answered no, or do not need frequent access to a machine, then a desktop is a more preferable choice
So whats the advantages and disadvantages of Desktops and Laptops?
Both are fairly good but do have limiting factors, here they are
Desktops
Positives
- You can get more for your dollar
- They will last longer
- They can be easily upgraded and maintained
- A Desktop can perform better then a laptop
- You can choose almost all of the parts in a desktop you want
Negatives
- They are large and heavy, not ideal for constant mobility
- You need to factor additional items like screen and speakers
- They have no backup source of power
- They take up power points and space
- They can get very dusty and cause overheating
Laptops
Positives
- Laptops generally come with all the features you need, like screens, speakers, software
- They are battery powered, and designed to be used almost anywhere
- They are small and lightweight, so they will not need as much space and resources
- Most popular places, like airports, have wireless internet access for the public to use
- They are good for people who have to travel for work
Negatives
- There is limited choice in what you can get extra
- They cost more then a desktop
- They need to be looked after very well as they can get damaged very easily
- They generally only have a life of 3-4 years
- The battery can become obsolete and they are very costly to replace
Once you have decided, here are the other areas you need to consider
Hard Drive Space
This is important, as you will want to have free space or your computer will not perform as well as it should. For general use, 120 GB+ is good. For people who make large files like movies or photos, you will want a 250GB+ and a external storage device
RAM and CPU
This determines how fast your machine is. Most computers will now run windows vista or 7, but ill also add XP as well
XP - 1GB RAM and 1.6GHz CPU minimum
Vista and 7 - 2GB RAm and 2.3GHz CPU minimum
Graphics
Gamers and multimedia are only really considered in this. If you use it for general things, the graphics provided is generally good enough. For people who need it, this is based on what you need it for and external research is needed.
Speakers
Laptops come with speakers per-installed. Desktops can vary, but some will need external speakers
Screen
Laptops come with a built in screen, desktops need a external screen with the correct input. The most common one is D-Sub (Also called RGB and VGA) and is a blue color adaptor. newer connections are DVI, S-Video and HDMI (HDMI is also a source of sound). When looking for a screen, make sure it will have the appropiate connections
Keyboard and Mouse
Laptops have these pre-built into them. Desktops need external ones. there are many types of wired and wireless keyboards and is based on personal choice
Power Supply and Motherboard
This is for people who wish to build their machine. Further research is needed to make sure all the above will be supported by the motherboard and Power supply
These are the main factors, so think about this then based on this information, you should have decided what you want.
For more information on these tips, or for more tips, or if you need to contact me about any computer related issue, please don't hesitate to contact me on FixYa!
Have a Nice Day
Tim Goulding
ICT Technician
Computers & Internet Logo
I am 72 and my Bp is 135/75 is this too high
There is no one right answer for this, as lots of factors need to be considered when deciding what constitutes what is and is not healthy for each patient. See your doctor :)
Aug 30, 2017 | Health & Beauty
Single phase or 3 phase
Hmmm. Good question. Like anything, it varies depending on how the equipment is going to be used and in what environment. We could really get into the weeds, but let's just ask the couple of key questions.
1. Is this a commercial or residential environment?
2. What's the horsepower of the motor(s) in use?
3. What's the availability of 3 phase power?
1. If your saw is in daily, commercial use, then 3 phase may offer some distinct advantages: While it's expensive to convert (assuming you don't already have 3 phase available) it allows for smaller, less expensive wiring, and lower voltages making it safer and less expensive to run.
Single phase, otoh, is much more available, and runs motors up to 5hp with little difficulty. It does actually cost more to run a lot of single phase equipment so if cost is an issue and you have quite a few motors, this may be a large determining factor.
2. As I mentioned, if you're only running one or a couple smaller motors, up to 5hp, single phase should work just fine. I have several pieces of machinery with 5 hp motors them on single phase 220 and they perform great. I don't recommend 110vAC for motors under significant load. They run too hot and are not all that efficient, as well as under-powered.
3. Installing a 3 phase electrical system can be very expensive. I would look into this carefully, get a few estimates before moving ahead. You'll need to find out if it's even available, cost of transformers for 110 in the building as well as whether they'll charge you commercial rates for your electricity once it's installed.
There is no simple answer for this question, I fear. There are simply too many factors to consider.
This is the short answer. A simple web inquiry will give you more answers than you actually need.
Good luck.
Jan 02, 2016 | Saws
What do I need to consider when buying toys for my dog?
Buying toys for a dog may seem so simple; however there are many factors to consider. First look at your dog and consider the following aspects: age, size and physical capabilities. Next consider yourself - maybe you work from home and need a lot of time to focus. In that case you should buy your dog distraction toys such as food delivery toys, chew toys and puzzle toys.
Jul 23, 2012 | Dogs
need to know which style of m b I have is it an atx
The difference between ATX and MicroATX is the size. An ATX board will usually have 6-7 slots to add cards like video, network or sound cards. An ATX board will also usually not have a video port on the board. A MicroATX board will usually have only 3-4 slots to add cards into it, at least one of which being dedicated to AGP or PCI Express Video cards.
To answer your question: That computer uses a MicroATX board. A Micro ATX board will most likely work in any PC Case whereas an ATX board requires an ATX size case (Mid or Full size Tower).
Jun 06, 2010 | eMachines T3508 PC Desktop
116 people viewed this tip
David Payne
David Payne
