Tip & How-To about Computers & Internet
Yahoo Messenger Error's!!
How many of us have seen Error Message's like :-
1. YPager.exe
2. Sorry for Inconvenience
3. Window's Unable to Download Yahoo Messenger
The Most Common Reason for the First and Second Error Message is Software Corruption. Whenever you see Error Messages 1 and 2, it always indicate there has been a recent change in Registry.
You could Read a Nice Article for the same :-
http://en.wikipedia.org/wiki/Windows_Registry
Now,
The ONLY way to fix this is to REINSTALL Yahoo Messenger.
Go to :-
Start > Control Panel > Programs > Uninstall Program > Select Yahoo > Uninstall
The Above steps are Generic One.
Then, Reinstall the Yahoo Messenger.
Now,
For Error 3, Make sure that you do have a Working Internet Connection and you are able to download other files. I have seen issue with Yahoo Messenger with Slow Connection.
Download the Yahoo Messenger from the Below Sites than from Yahoo Messenger Site :-
http://www.download.com
http://brothersoft.com
As of now, let me provide you with a Link from where you could directly Install Yahoo Messenger ( Link working right now ) :-
http://www.softpedia.com/progDownload/Yahoo-Messenger-Download-4411.html
If Problem still Persists, Seems that there is a Virus/Adware/Spyware problem. It could also mean a problem with Windows.
In that Case, Either Restore or Reinstall Your Windows.
Thanks!!
Computers & Internet Logo
WHILE installing yahoo! Messenger I got an error message said a network error was encountered unable to download files neededr install. retry went no where turned off fire wall ...no joy
Hi Michael,
Wishing you and your family a very Happy New Year. Sorry for being late to reply as I was busy with my family this weekend. Before suggesting you any solution I need to know a couple of things. Please reply asap.
1) Which Operating System are you using? (like windows XP, vista etc)2)From which website you are trying to download yahoo messenger?3)which internet browser are you using? (like IE,firefox etc)
Hoping to get a reply back soon.RegardsAvishek
Jan 01, 2012 | Yahoo Messenger
Yahoo! Messenger has encountered a problem and needs to close. We are sorry for the inconvenience.
Welcome to FixYa! Are you using window blinds or alienguise or some other window enhancement program? Examples are programs that add extra buttons like transparency and keep always on top or change the look of the windows in anyway (not including standard XP themes), if so disable it and yahoo should work.
Do a search on http://www.wackyb.com for window blinds as it's discussed there often :)
This is sometimes a flash issue, make sure you have download and installed flash from Internet explorer (not any other browser)
http://www.adobe.com/shockwave/download/...
Still having problems try Common Issues/Tips & Tricks here:
http://www.wackyb.co.nz/Yahoo!_Messenger...
Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | Yahoo Messenger
i deleted my old yahoo messenger from the computer and now i am trying to install a new one but its not working, every time i try to install it, it says(yahoo messenger is unable to download files needed for installation. please check firewall settings and retry.) what should i do???please help me
the error message is clear, for some reason your computer is set to block the Yahoo messenger link.
here is what you can do: (for windows XP)
1. open Control panel
2. click on Security Center
3. click on Widows Firewall
4. click on the Exception tab
5. check if you have Yahoo Messenger there:
a. if not: click on Add and paste the follow: C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
b. if it's there- make sure it is the same as C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
if it is the same- click on Delete to remove it and try to install again.
Oct 17, 2010 | Yahoo Messenger
application error occuring to install or remove yahoo massenger?
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Failure to initialize error message persisting? try this download site
http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Jan 09, 2010 | Yahoo Messenger
when i make a call the messenger doesnt allow it and says sorry,but we were unable to place yourcall,please try again later
delete existing messenger and download ver 9 with voice and try it will work
or
If you got yahoo messenger call error then there is a 94% chance that your computer has registry problems. To repair yahoo messenger call error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair yahoo messenger call error
Here are the url of Perfect Optimizer: http://www.fixerror365.com/tidpp-yahoo_messenger_call_error-zz0001
Nov 09, 2009 | Yahoo Messenger
202 people viewed this tip
David Payne
David Payne
