Tip & How-To about Vacuums
To remove transmission fluid.
If over fill transmission , you can take a turkey baster ,cut a pencil size hole in the bulb, add on a peice of 3/8 tubing about 3 ft long to the other end.Put the tubing down the fill tube.Squeeze the bulb ,then with the bulb squeezed cover the hole with your finger and release the bulb. Repeat this prosess removing your finger only long enough to sqeeze the bulb again.After doing this several times your turkey baster will be full of trany fluid,Pull your new tool 3/8 tubing and all out of fill tube and drain into an empty container.[ This will remove about a pint of fluid at a time ]
Vacuums Logo
Northwest queen air mattress
You can always make a plug. Get a piece of clear vinyl tubing about 1 inch long. The inner diameter of the tube should be the same size or just a bit wider then the width of the mattress plug your missing. Get a small tube of clear silicone rubber (make sure its pure silicone rubber) and completely fill the vinyl tube. Let it sit for 4 or 5 days to completely dry. Cut off the vinyl and your new plug emerges! Use your scissors to cut the tip at an angle so its easier to get it into the mattress tube.
Mar 24, 2015 | Vacuums
it wont disperse water
You need to post with information. This is to vague of a question so it is a waste to even post. Brand make and model is a must. For all I could tell you may have a turkey baster.
Feb 27, 2015 | Vacuums
Nikken Air Purifier, Model NKAP100: Change Filter red indicator stays lit after new filter has been installed
Under the front panel, under and to the right of the control panel is two holes, one the size of a pencil eraser and below it is one the size of a dime. In the hole (the size of a dime), is a pin hole use a paperclip and poke the hole. It will reset the filter light. We had the same problem, and couldn't find the manual. Our Nikken rep was No help either.
Apr 20, 2011 | Vacuums
how do i change the fill tube
Cut the old fill tube from the lower housing and remove the top adapter from the old tube. Clean the bag and housing to be sure the spout the tube attaches to is clean. Be certain to use the fill tube used in the Generation 3 and 4 models which has a wire in it. Wet the lower few inches of the tube and screw it fully onto it's base in the lower housing. The upper adapter can be attached with cable ties.
Jan 05, 2011 | Kirby G4 Bagged Upright Vacuum
My bissell Powerbrush cleaner quit working. The
found it from Tara put online in nov 2008 Thanks this is it
Had the same problem... although I don't have particularly hard water, the heater block corroded just enough to stop most of the flow after about 4 years. Disassemble the handle to get at the heater block (3 pairs of screws/bolts), remove the tubes with needle nose pliers, use a paper clip to knock out the corrosion on the front tube on the heater block, flush with a syringe to get rid of any other bits of corrosion (some extra plastic tubing connected to the back tube of the heater block helps here, and catch the water from the front tube to prevent water in the electronics...), reassemble (avoid disconnecting any wires...) and try it out. Worked for me! I REALLY have to thank the person who suggested this fix! THANKS!!!
I used regular pliers , phillips screwdriver , the pointed end of a compass and a turkey baster full of water to blast it out . You have to improvise . Take your time watch the little rubbers on the heater make sure its not hot . It was just the inlet gets pluged up in the heater . You have to take off the tools then its the bottom set of plastic not the handle . You can test by pushing the plunger at the top . You must take the handle off . Loosen the pieces it just came off for me then snaps back on . This is all it was for me , very simple . I am disabled and did it on a extra old carpet a little at a time over a few hours . For someone healthy its a hour job tops or less . Just be patient . God helps those who help themeslves and asks for patience .
Mar 15, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
164 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
