Tip & How-To about Heating & Cooling
Beckett Oil Burner Problems What to do if you run Out of Fuel Oil
Running out of heating oil is not all that uncommon. There are many things that can go wrong causing you to run out. When this happens do not panic, you can get your oil burner up and running rather quickly if you know what to do
You forgot to get more heating oil for your furnace and now you have run it out of oil. The first thing you need is a container that will hold at least five gallons of liquid. A container approved for flammable liquids is always the best. I really would not want you to use that camping water jug. It will ruin it for any future water use.
Now locate the closest place that sells either regular diesel, off road diesel, or kerosene.
Any of these will work to get you going. Never use any type of gas in your oil burner!
You will need at least five gallons to get the level of the liquid in the tank over the intake pipe so that you can prime the pump. Once you get the fuel into the tank you should wait for at least ten minutes to let the fuel settle back down before you try to light the burner.
Dumping the fuel into the tank with very little liquid in there will stir up all the sludge in the bottom of the tank and if you try to pull it into the burner while the sludge is suspended you will just create more problems.
Now that you have the fuel in the tank you can begin to try to start the burner. If your are fortunate enough to have a TigerLoop installed in your fuel line then just pushing the reset button will purge the air and with a couple of clicks of the button you will be heating again. If you do not have a TigerLoop the burner pump has a two pipe system the pump will usually purge the air eventually but it may take quite a few resets to get it going. If you have a single pipe system, then look for my article on bleeding your pump.
Running your oil burner out of oil happens and you can remedy the problem if you know what to do. Usually this will happen on the coldest night of the year or on a holiday weekend when a service call will cost you your firstborn to get you warm again. Now you can at least get warm till you can get the tank filled at a reasonable cost.
Heating & Cooling Logo
i have a 96 monte carlo with a 3.1 if 20/50 what will happen
its not the worst thing you can do oil still protects motor ,I would change it AS/AP it can cause pump to work harder to move oil,and slow movement due to thickness. bad gas mileage could be air cleaner ,spark plugs,bad wires,motor running on the rich side
Sep 11, 2014 | Cars & Trucks
My John Deere 3000 pressure washer heats up after only a few minutes running and shuts off. This has happened numerous times.
Could be that the motor is low on oil, if the Honda engine runs low on oil it will shut down after running for a couple minutes. I would check that first. If you still have a problem next time before it shuts down take the gas cap off, it is possible that your gas cap is bad and is causing a vapor lock in the tank. Anything other then these items will indicate that something is wrong with the carb.
Nov 09, 2010 | Garden
scored cylinders leading to an oil consumption problem
Several possibilities, one or all could have happened. Low oil level, not changing the oil filter and oil when needed, wrong type of oil, Spark plugs with the wrong heat range, not using premium gas, oil pump problems, air leak in the intake leaning the fuel mix, poor seal on the head gasket, bad exhaust valve(s), timing is off and a few other things. What is listed are the usual things causing an engine to overheat. If fuel injected, get that checked too. It could be a lean mix there. In any event, overheating is the cause. Now just find out what caused the overheating.
Please rate this answer. Thanks!
Jun 06, 2009 | 2001 Victory V92 Cruiser
Would like to talk with a car repair guru, not a computer guru
i think you have a combonation of problems here. most of it lead to needing a tune up .
just to get an understanding what is going on in your engine . i would bet to say that your enagine light is on . and probily an engine misfire code.
when the engine misfires somtimes it wil activate your knock sensor and ****** the timing thus raising your engine temp. if you havent flushed your coolant system yet you should. new plugs and wires and clean your throttle body.
good luck
Nov 02, 2008 | 2002 Chevrolet TrailBlazer
658 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
