Tip & How-To about Washing Machines
WhirlpoKenmore washing machine -- can hear motor running, nothing happens
Whirpool (and Kenmore, which are made by Whirlpool) washing machines do not have belts to drive the transmissions. They use a motor coupling, which is a common failure point on them. If this happens, it is a cheap (about $20) and easy fix. First, tilt the washing machine back and block it up safely. Next, locate the motor. There will be two steel clips holding the motor on. Each of these clips has a 5/16" (8mm) bolt holding it. Remove the bolts and pry the clips off, being careful to support the motor (it would hurt if it landed on your head) Pull the plastic halves off of the motor and transmission and discard along with the rubber disc that goes in between them. Put one of the new plastic pieces on each side, making sure that it is all the way on. install the rubber disc then the motor, making sure to line the prongs up with the holes in the disc. Snap the clips back into place and reinstall the bolts. Now do your laundry (after releveling the machine, of course)
Washing Machines Logo
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    how do i know if my washer has a belt
    If this is a Kenmore top loader resembling the one you posted this question under, it does not use a belt. Kenmore washers are manufactured by Whirlpool. They use a motor coupling in place of the drive belt. It couples the drive motor to the gearcase (transmission). This configuration is known as a direct drive system. For future reference you should include a MODEL NUMBER when posting your question, so I can confirm how the washer is configured. If you need further assistance, please let me know. I hope this helps you.
    Feb 15, 2010 | Kenmore 24032\24036 Top Load Washer
    Whirlpool washer drive problem
    ck coupling between motor and transmission ..whirpool part # 285753a
    Nov 21, 2008 | Washing Machines
    Older kenmore washer doesn't agtat the frist load but works fine the rest of the day (has new belt) moter works fine
    If your washer doesn't agitate, check these:
    Lid switch
    Motor coupler
    Belts
    Clutch
    Drive motor
    Drive pulleys
    Transmission
    Agitator
    Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
    Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Transmission The transmission could have either of these problems:
    • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
    • The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
    From Repairclinic
    Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
    My whirlpool top loader extra large washing macine
    Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
    Aug 07, 2008 | Washing Machines
    236 people viewed this tip
    Top Washing Machines Experts
