Tip & How-To about Cell Phones
Protecting electronic devices from moisture condensation
You probably already know electricity and water don’t mix. It’s especially true when that mixture happens inside your mobile phone, MP3 player, Blackberry or PDA. The tiny electronic components inside these devices can stop functioning either temporarily, or permanently, if enough moisture collects on them.
Rarely does anyone think about this, but consider a day that you spent outdoors, at the beach or amusement park. There is little doubt that you won’t have some type of electronic device in your pocket or, like some teenagers, permanently affixed to your hand and/or ear.
On days when the outside air is especially warm, your electric device’s components are going to be even warmer due to the electrical currents within. If you walk into an air-conditioned building to cool off, the device will also begin to cool. Condensation can develop on the device anytime the temperature of the air surrounding the device is altered; either by going from hot to cold, or from cold to hot. Often, condensation develops on the LCD monitor or sometimes inside camera lenses and causes water spots or fungus.
To prevent condensation from developing on your electronic device when transitioning between two different temperature zones, place the device inside a sealed plastic bag until the temperature of the device is closer to the temperature of the surrounding air. Condensation will develop on the outside of the bag, instead of on, or in, the device.
In areas of extremely high humidity, condensation may still develop. If you see that moisture is beginning to develop on the device, turn of the power for a couple of hours until the temperature of the device has reached the temperature of the surrounding air.
This is also why, in my opinion, it is best to avoid turning electronic devices (of any kind) on and off repeatedly. Not only to prevent condensation, but the expanding and contracting of electrical component due to heating and cooling causes unnecessary metal fatigue.
Happy Transphonetexting,
Randy
Cell Phones Logo
I have a 2001 ford focus, my wife spilt water on the gear shifter and now the overdrive light will not go off even if the button is pushed
First of all...water and electrical connections don't mix well. Since the overdrive button is located on the left side of the shifter, and your wife spilled water on the shifter, the water has likely caused an electrical short.
With the ignition key off, try using compressed air to blow out any possible water or moisture around the shifer button and at the base of the shifter itself. Since the overdrive button has electrical connections inside the shifter, the water has probably caused a short. (I repeat...water and electrical connections don't mix well) If this doesn't cure the problem, you may need to disassemble the shifter mechanism and check for water or moisture. The electrical connections or wiring may be wet inside the shifter, which is likely causing the problem. Blow the areas out with compressed air and make sure everything is clean and dry. Then reassemble the shifter mechanism and reheck to see if this cures the problem.
Good Luck!
May 17, 2012 | 2001 Ford Focus
What is the best coolant for my 2001 Dodge neon? It is hot here where I live and I don't want anything to happen to the car/
any of the green or universal antifreeze will work... you have to mix a 50/50 mixture with water, the antifreeze isnt actually doesn't conduct the heat, thats what the water is for. antifreeze is only to keep your water from freezing in the winter, also to lubricate your water pump and is to prevent the water from corroding or rusting the inside of your engine.
Aug 09, 2011 | 2001 Dodge Neon
the camera was dipped into water and it was not functioning right now.
It could already be dead, water and electricity don't mix, but you could try this.
Take out the battery (If anything like this ever happens again, camera, mobile phone, anything electrical, remove batteries immediately).
Put it in a dry warm place, airing cupboard, over a radiator (but not on) for a few days to dry out the circuits, then put the battery in and try again.
If it doesn't show any signs of life then, I'm afraid its had it. But if you've accidental damage cover on your home insurance, you should be able to claim against that for a new one.
Apr 14, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
mix stick wont play music
What's a mix stick? We need your model # and manufacturer. Are you talking about the Disney Mix Stick? Make sure the files are in mp3 format - i know it says that it will play WMA files, but that was before DRM encryption came along. Also, this player is not compatible with iTunes. This product does not have a manual available that I can find - IF AND ONLY IF your songs are already in mp3 format, and the player is still not working, double check the manual to see if there is a reset button.
If all else fails, this website will give you helpful info, including the phone number to get help on this product:
http://disney.memorexelectronics.com/html/support.php
Jul 06, 2008 | Audio Players & Recorders
SIDEKICK 3
Do you want to know if it's your cp is still working?
First, make it sure it's totally dry without any water or moist before turning on the device.
Second, if it's OK and you know it's out of water inside and the cp was total dry, turn it ON.
Third, if you're not sure and you don't want to take the risk by turning it ON, it is a better option for you to bring it into any cp service center near you.
Cheers
Feb 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
2,218 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
