Tip & How-To about Computers & Internet
What is the Registry?
The Registry is a database used to store settings and options for the 32 bit versions of Microsoft Windows including Windows 95, 98, ME and NT/2000. It contains information and settings for all the hardware, software, users, and preferences of the PC. Whenever a user makes changes to a Control Panel settings, or File Associations, System Policies, or installed software, the changes are reflected and stored in the Registry.
The physical files that make up the registry are stored differently depending on your version of Windows; under Windows 95 & 98 it is contained in two hidden files in your Windows directory, called USER.DAT and SYSTEM.DAT, for Windows Me there is an additional CLASSES.DAT file, while under Windows NT/2000 the files are contained seperately in the %SystemRoot%\System32\Config directory. You can not edit these files directly, you must use a tool commonly known as a "Registry Editor" to make any changes (using registry editors will be discussed later in the article).
The Structure of The Registry
The Registry has a hierarchal structure, although it looks complicated the structure is similar to the directory structure on your hard disk, with Regedit being similar to Windows Explorer.
Each main branch (denoted by a folder icon in the Registry Editor, see left) is called a Hive, and Hives contains Keys. Each key can contain other keys (sometimes referred to as sub-keys), as well as Values. The values contain the actual information stored in the Registry. There are three types of values; String, Binary, and DWORD - the use of these depends upon the context.
There are six main branches, each containing a specific portion of the information stored in the Registry. They are as follows:
* HKEY_CLASSES_ROOT - This branch contains all of your file association mappings to support the drag-and-drop feature, OLE information, Windows shortcuts, and core aspects of the Windows user interface.
* HKEY_CURRENT_USER - This branch links to the section of HKEY_USERS appropriate for the user currently logged onto the PC and contains information such as logon names, desktop settings, and Start menu settings.
* HKEY_LOCAL_MACHINE - This branch contains computer specific information about the type of hardware, software, and other preferences on a given PC, this information is used for all users who log onto this computer.
* HKEY_USERS - This branch contains individual preferences for each user of the computer, each user is represented by a SID sub-key located under the main branch.
* HKEY_CURRENT_CONFIG - This branch links to the section of HKEY_LOCAL_MACHINE appropriate for the current hardware configuration.
* HKEY_DYN_DATA - This branch points to the part of HKEY_LOCAL_MACHINE, for use with the Plug-&-Play features of Windows, this section is dymanic and will change as devices are added and removed from the system.
Each registry value is stored as one of five main data types:
* REG_BINARY - This type stores the value as raw binary data. Most hardware component information is stored as binary data, and can be displayed in an editor in hexadecimal format.
* REG_DWORD - This type represents the data by a four byte number and is commonly used for boolean values, such as "0" is disabled and "1" is enabled. Additionally many parameters for device driver and services are this type, and can be displayed in REGEDT32 in binary, hexadecimal and decimal format, or in REGEDIT in hexadecimal and decimal format.
* REG_EXPAND_SZ - This type is an expandable data string that is string containing a variable to be replaced when called by an application. For example, for the following value, the string "%SystemRoot%" will replaced by the actual location of the directory containing the Windows NT system files. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_MULTI_SZ - This type is a multiple string used to represent values that contain lists or multiple values, each entry is separated by a NULL character. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_SZ - This type is a standard string, used to represent human readable text values.
Other data types not available through the standard registry editors include:
* REG_DWORD_LITTLE_ENDIAN - A 32-bit number in little-endian format.
* REG_DWORD_BIG_ENDIAN - A 32-bit number in big-endian format.
* REG_LINK - A Unicode symbolic link. Used internally; applications should not use this type.
* REG_NONE - No defined value type.
* REG_QWORD - A 64-bit number.
* REG_QWORD_LITTLE_ENDIAN - A 64-bit number in little-endian format.
* REG_RESOURCE_LIST - A device-driver resource list.
Computers & Internet Logo
i have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i need to get a firmware update from belkin ? at the moment the router is version 1.00.03 as of the 9th july 2008. regards
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
Nov 28, 2017 | Computers & Internet
I have a PC with motherboard MSI MS 6702, I cant find the Ethernet controller driver for it ! Thanks for help
I got drivers for you. The first link is for win vista32 and vista64 drivers.
2nd link is for XP32, win 2000, win 95,98, NT and all other pre vista versions.
If you need drivers for other OS, PM me.
Link1: http://www.ziddu.com/download/15101799/Realtek_Gigabit_NIC_Vista.zip.html Link2: http://www.ziddu.com/download/15101800/Realtek_Gigabit_LAN_MB.zip.html
May 24, 2011 | Computers & Internet
why will printmaster platinum 2.0 not uninstall
Try using the Windows Installermag-glass_10x10.gif CleanUp Utility. As long as you installed the application using the Windows Installer, this utility will remove all the folders, files, registry keys, and entries from your system and allow you to start over with a clean slate.
Download the Windows Installer CleanUp Utility
Locate and run msicuu2.exe to install the Windows Installer CleanUp Utility.
Locate and launch the Windows Installer CleanUp Utility on the Start menu.
From the Windows Installer CleanUp Utility window, locate the application in the list and click the Remove button.
Once the application has been removed, click the Exit button to close the utility.
You may now reinstall the application or at least have piece of mind that it is gone
This version of the Windows Installer CleanUp Utility works correctly in all 32-bit versions of Microsoft Windows. The 32-bit versions of Microsoft Windows are: :
Microsoft Windows Server 2003
Microsoft Windows XP
Microsoft Windows Millennium Edition
Microsoft Windows 2000
Microsoft Windows NT 4.0 with Service Pack 3 or later
Microsoft Windows 98
Microsoft Windows 95
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Broderbund PrintMaster Platinum 16
i need to reset administator pass word for windows vista but i cant down load anything cus i have to be in the administator mod
There are a lot of tools and utilities that can be downloaded and used to recover, reset, retrieve or reveal existing password. These password reset or retrieval utilities, free or paid, are usually a Linux boot disk or CD that able to comes with NT file system (NTFS) drivers and software that will read the registry
and rewrite the password hashes, or can brute force crack the password for any user account including the Administrators. The advantage is that there is no fear of leaking your password to outsiders, while the process requires physical access to the console and a floppy or CD drive, depending on which tool you choose. And it’s not easy, although it always work!
Offline NT Password & Registry Editor – Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000,Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
Download Links:
http://home.eunet.no/~pnordahl/ntpasswd/cd080802.zip
http://home.eunet.no/~pnordahl/ntpasswd/bd080526.zip
Let me know how did it get out.
Sharon
Feb 02, 2010 | Microsoft Windows XP Professional for PC
regestry editor
A central hierarchical database used in Microsoft Windows 98, Windows CE, Windows NT, and Windows 2000 used to store information that is necessary to configure the system for one or more users, applications and hardware devices.
The Registry contains information that Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used.
The Registry replaces most of the text-based .ini files that are used in Windows 3.x and MS-DOS configuration files, such as the Autoexec.bat and Config.sys. Although the Registry is common to several Windows operating systems, there are some differences among them.A registry hive is a group of keys, subkeys, and values in the registry that has a set of supporting files that contain backups of its data. The supporting files for all hives except HKEY_CURRENT_USER are in the %SystemRoot%\System32\Config folder on Windows NT 4.0, Windows 2000, Windows XP, Windows Server 2003, and Windows Vista. The supporting files for HKEY_CURRENT_USER are in the %SystemRoot%\Profiles\Username folder. The file name extensions of the files in these folders indicate the type of data that they contain. Also, the lack of an extension may sometimes indicate the type of data that they contain.
Jun 20, 2008 | Microsoft Windows Vista Ultimate Edition
191 people viewed this tip
David Payne
David Payne
