Tip & How-To about Washing Machines
Replacing a Lid Switch
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
Washing Machines Logo
how do i replace my lid switch?
If you are referring to the lid swtich on a Whirlpool manufactured top loading washer (such as Estate, Kenmore, Roper, Frigidaire and some later model Maytags), the following link explains step-by-step:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, or if your washer is not a Whirlpool model, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid, or on the back of the control panel) and let me know. I hope this helps you.
May 05, 2011 | Washing Machines
need to replace safety switch. How do I remove or lift the lid to replace switch?
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
May 03, 2011 | Kenmore Washing Machines
How do you replalce the switch,lid
If this is a Kenmore, Estate, Roper, or any other Whirlpool manufactured top loading washing machine, the following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS If you have any other brand washer please post back with your model number so that I can verify how it is configured.
Jul 26, 2009 | Washing Machines
10,865 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
