Tip & How-To about Computers & Internet
Virus detection made easy.
Hi, here is a simple tip to know if your PC with WinXP is infected by a virus.
  1. goto start, my computer
  2. on the my computer window, click tools, then folder options (oops! no folder options, your PC is infected.)
  3. on the folder options window, click the view tab
  4. on the view tab, click Show hidden files or folder
  5. click ok
  6. on the my computer window, click again tools, then folder options
  7. on the folder options window, click the view tab
  8. on the view tab.....
If the view tab shows the Do not show files and folders option being selected again. your PC is infected with a virus. Else your PC is safe for the moment. Of course the best way is to run an antivirus software that scans for viruses and malwares. = )
Computers & Internet Logo
Failing to log in and freezing when when the windows xp starts to load
It mayt be infected with virus , if you have any virus scanner , go to safe mode by tapping f8 key when computer starts and run a deep scan i mean full scan , if still you face the same issue , go to normal mode and restore the computer using system restore to a date where your computer was working fine ,make sure programs installed after that date wil be gone however data saved on the hard drive would be safe .
so use it wisely .
directions to go to system restore
1. click on start
2. go to programs
3. then goto accessories
4. then system tools
5. select system restore .
Jul 07, 2010 | Dell Inspiron 700M Notebook
Further help required
Hi, the Deep Virus Scan simply means to scan your whole system for viruses (all files on your system, can take a long time),
The virus program in question must be updated daily otherwise it won't find the latest infections.
Defrag C: means goto Windows Explorer, right button click the C: drive , select the tools tab, goto defragmentation and start defragging,
Hope this helps.
Regards
GeWiz.
Dec 10, 2009 | Samsung R610-64G Laptop
will not play....Charter Security says "malicious code found in file C, infection SDBot.gen9
You have a backdoor worm/virus that's infected your machine.
If you use WinXP click on the start menu and click on the run box, in the box type mrt.exe and hit the enter key, Microsoft's malicious removal tool window will pop up and you can scan and delete and malicious software from C drive, in the options part have it scan the whole computer, be patient as it will take some time to complete.
If its Vista you use scan the computer with your antivirus software.
Good luck
Jun 29, 2009 | Arcsoft TotalMedia Extreme - Windows for...
virus free pendrive
goto my computer, right click on drive, choose format, do this on a non-infected pc
Apr 11, 2009 | Computers & Internet
my pc
there are many things that causes your pc to function slowly. one of which is that your pc might be infected by a virus. you can install an antivirus and at the same time update its virus definitions so that it can be able to clean you computer. also, your hard drive might be running out of space, all you need to do is remove unused files to free up some space. you can also check if your computer is compatible with your operating system. if your OS is new and your computer hardware is slow, then it miht cause your computer to slow down.
Jan 20, 2008 | E-Machines eMachines Desktop PC
136 people viewed this tip
David Payne
David Payne
