Tip & How-To about Computers & Internet
Pervent your laptop from crashing
do not block your laptop fan respirators under and on the side of the pc , do not keep the pc on all the time meaning days and nights continous keep your pc a litle bit rase above the table or the surface where it stands so will be very well ventilated and if you let spill some liquid on your laptop frist take of the battery and p[ower cord even if on so it dont short out the interior board and til the pc so rthe liquid ill drip of the surface of the pc and try to dry it whid a bow dryer
Computers & Internet Logo
Why is my laptop getting hot right where I rest my left hand when I type?
Probably where your graphics card and/or CPU is located under the bezel. Make sure you are not blocking the vent holes on the laptop, and try to keep the laptop raised in back to allow heat to dissipate. If it's old enough, the fans might be blocked with dust and/or failing, in which case the laptop won't cool properly.
Nov 07, 2014 | HP Computers & Internet
laptop crashed
Really need more information, but my guess is dirty fan. If fan is blocked by dust, it may make noise and may run at high speed all the time because the CPU is overheating. If CPU gets hot enough, the laptop will shut itself down without warning. If dust is the problem, get some canned air. Before blowing into the air vents, try to spot where the CPU fan is and gently insert a toothpick to block the fan and prevent it from turning. A long blast of compressed air can spin the fan too fast and burn out its delicate bearings. Blow air from underneath and also from the side vent until air blows clear. In some bad cases of dust, the bottom or top cover must be removed to get it all out.
Sep 25, 2013 | Dell Vostro Computers & Internet
My vostro beeps 5 times continously from startup till on windows. pls help out
Hi Femi,
5 beeps on a Vostro generally means that the internal CMOS battery (the one responsible for your laptop keeping its time etc) has failed and needs to be replaced. You're best taking the laptop to a local computer shop to get the CMOS battery swapped out.
Many thanks,
Jon.
Aug 29, 2013 | Dell Vostro Computers & Internet
television is now 4 years old, have replaced the lamp 4 times, last time was last week, this lamp lasted three days am waiting for new lamp to see if the last one was faulty. is this a common problem blowing lamps? is there not enough air flow ? are other owners experiencing this?
Make sure all Airways do not have alot of dust builted up blocking Airways this can cause Lamps to Blow, also keep in mind these sets are only desinged to play between 5000 to 8000 hrs you cannot leave them on day and night like regular TVs,and yes New Lamp does not mean that it was not Defective sometimes companys do have a run as to where they have alot of defective Lamps it Happens
Mar 16, 2009 | Loewe Articos 55 55" Rear Projection...
lap top computer
Jul 07, 2008 | HP Pavilion dv1000 Notebook
217 people viewed this tip
David Payne
David Payne
