Tip & How-To about Garden
Diagnosing your small engine, string trimmer, chain saw, leaf blower, briggs problems
Do you have a push mower, leaf blower, string trimmer, etc. that wont run; and you dont know which direction to go to fix it? The majority of problems are fuel related and this is a fast, easy way to determine if it is or not.
Start be removing the air filter and verifying that the choke is open ( run position). Then, spray a shot of carb cleaner ( available at any auto parts store, wal mart or dollar general) into the throat of the carb. Attempt to start the unit. If the unit hits on the prime ( starts and runs briefly on the carb cleaner) then the problem is fuel related. You should check your fuel ( water or stale), fuel lines and filter, and carb. If the unit does not hit on a prime then you should start checking your ignition system and compression.
Garden Logo
how do I find replacement string for a lawn trimmer?
home depot has trimmer string. as well as most hardwares.
Jul 26, 2014 | Toro Lawn Mower With Toro Power Tools
string flys out when engine reved up
It sounds like you are winding the line in the wrong direction. You should wind the line in the opposite direction that the head spins during operation.
Good Luck!
Jim
Jul 30, 2011 | Troy -Bilt String Trimmer/Blower...
214 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
