Tip & How-To about Sony PlayStation Portable (PSP) Console
How to get PSP themes
It is achally really easy just get a theme then in your PSP put a rolder named THEME capatalized put it in the psp folder.then simply put your downlouded theme to the theme folder.you can get themes by going to any web site with thgem EX. PSPthemes.com or you can also downloud thems by dowloudeing them in your PSP internet browser
Sony PlayStation Portable (PSP) Console Logo
themes that i downloaded,where should i put it??because i putted it in the themes but it is not there when i want to use it as my theme
You have to first download the theme off your computer, you cant get it from your psp's web browser. Then after you connect the psp to your pc, you have to make a new folder in the root of your psp memory card named "THEME". All you have to copy into the THEME folder is the .ptf file. The .ptf file is the theme. Then after you should be able to see it in your psp. Hope I helped!
Aug 06, 2011 | Sony PlayStation Portable (PSP) Console
how to put themes on my psp
if you really want to put themes on the psp..if you connect your psp on the pc youll see there all the folders of your psp..look for the theme folder and put the selected theme on it..then chose the downloaded theme from the theme setting menu..also u can use pic as your background..
Mar 10, 2010 | Sony PSP-3000 Silver Console
question
  1. Connect your PSP in the computer
  2. Go to PSP Folder
  3. And Then Select Theme
  4. And then Download A PTF File inside the Theme folder
That's all :)
Dec 18, 2008 | Sony PlayStation Portable (PSP) Console
i am not able to download themes in my psp
You don't have to create a themes folder on the on the memory stick duo, it is already created on the memory stick duo, all you have to do is to just connect your psp to your computer and activate the USB connection under settings on your psp, if you have firmware update 5.00 or higher, there is a feature called USB auto connect under system setiings which automatically switches to USB mode when you plug in a USB cable to your psp and your computer.
STEPS TO DOWNLOAD THEMES TO YOUR PSP.
1. connect your PSP to your computer, go to MY COMPUTER on your desktop and click on the drive that represents your PSP.
2. double click your PSP drive and navigate to PSP folder and select THEME under the folder.
3. Now copy and paste this link to your browser to download many themes for your PSP: http://dl.qj.net/index.php?&catid=538&name=PSP-Themes-PSP-&p10=5
4. select the file you want, click on download, depending on your browser, click SAVE when you are prompted to RUN or SAVE the downloaded file. Please select the PSP drive under MY COMPUTER and select PSP, navigate to the THEME folder and save the file to this folder.
Now disconnect the PSP from your computer and select THEME SETTINGS on your PSP, select THEME, navigate to the available themes and you will see a preview of the theme, select apply to use the new theme.
PLEASE RATE ME.
Dec 14, 2008 | Sony PlayStation Portable (PSP) Console
can't find themes
create a folder with name "THEME" under the folder 'PSP' in your memory card, then try to drag your downloaded ptf files into the "THEME" folder.
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
484 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
