Tip & How-To about Computers & Internet
Windows 7 System Restore is a bit different then Vista or XP Windows . Right-click Computer, select Properties > System Protection > System Restore > Next, and choose the restore point you'd like to use. Click the new button to 'Scan for affected programs' and Windows will tell you which (if any) programs and drivers will be deleted or recovered by selecting this restore point.
Computers & Internet Logo
what should i download to get 32bit operating system software
What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information.
The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
1. Open System by clicking the Start button , right-clicking Computer, and then clicking Properties.
2. Under System, you can view the system type.
If your computer is running Windows XP, do the following:
1. Click Start.
2. Right-click My Computer, and then click Properties.
If you don't see "x64 Edition" listed, then you're running the 32-bit version of Windows XP.
If "x64 Edition" is listed under System, you're running the 64-bit version of Windows XP.
Download it here:
https://www.microsoft.com/en-in/software-download/windows8
Mar 29, 2017 | Computers & Internet
Where do I go in the system to set the default storage to the sd card?
SD storage card restore to defaults
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Take Off Write Protection on an SD Card
Secure Digital (SD) flash memory cards are a common storage format for mobile devices.
By default, they allow both reading from and writing to the card.
However, they can be set so you can only read from the cards and not write to them.
Some cards are created as read-only by default.
Other times, a faulty card reader may mistakenly read all cards as read-only.
In both cases, you can make simple changes to the card to disable the write protection.
1.
Orient the card so the label is facing up.
Slide the write protection tab, which is located on the left side of the card, to the unlocked position.
If there is no write protection tab, skip to Step 4.
2.
Test the card in your computer.
Insert the card in the SD slot and open the folder to view the files.
Try to save a file onto the card or right-click an existing file and select "Properties," then uncheck the box marked "Read-only."
3.
Remove the card and check to see the write tab is still set to "unlocked" if you get a message that says it is still write-protected.
If it has become locked again, slide it back and tape it in the unlocked position.
4.
Place a piece of masking tape over the notch in the SD card located on the right side of the card. Make sure the tape does not cover any of the card's metal contacts.
Test again as in Step 2.
5.
Cover the notch with a second layer of tape if the card is still giving you problems.
http://www.getflashmemory.info/hack-why-is-my-sd-card-write-protected/
Aug 15, 2013 | Avatar Sirius S701-R2A-1 4GB NAND Flash 7"...
cosa devo fare dopo il ripristino
google translated
What should I do after recovery
Create a resore point
Click start right click on computer select properties windows update once an update has been installed a new restore point will be set.
or if no updates are available
Click the Windows Start button, right-click "Computer" and select "Properties."
Select "System Protection" in the left menu.
Enter your administrator password or click "Continue" if prompted by the computer.
The "System Properties" window appears.
Click the "Create" button near the bottom of the window to open the System Protection window, which prompts you to enter a description for the restore point.
Type the description in the text box and click "Create."
The restore point is created and a confirmation window appears on the screen.
Click "OK" to exit the window.
Hope this helps
Nov 04, 2012 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
How do i turn on the system restore point since the box where it says " Turn off System Restore ( disabled by Group Policy) was checked and there's no way to uncheck it?
Right click on "My Computer" (XP) and scroll down to "Properties". System Restore should be right over the General tab and just un-check "Turn Off" and click Apply. Click here for a tutorial for Win 7 and Vista http://www.sevenforums.com/tutorials/330-system-protection-turn-off.html
Mar 31, 2010 | Toshiba NB205-N210 Netbook
136 people viewed this tip
David Payne
David Payne
