Tip & How-To about Cell Phones
Pairing code for Bluetooth devices
Most Bluetooth devices such as phones, headsets, etc., they are using 1234 or 0000 as their own default pairing code.
Cell Phones Logo
I have had this bluetooth for a while but never used it. Trying to pair it With my new iPhone and dont remember having a PIN #. what do I do now? Or can I use it?
The default pass code is "0000."
Here's how to pair it with the default pass code:
  1. Turn the Bluetooth on and hold down the button until the light turns solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000"
May 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I am unable to pair my motorola blue tooth with my LG Wine
You must enter the default Bluetooth pairing code, on your phone, when prompted. The code is 0000 (four zeros).
For your reference, the brand of a Bluetooth device has nothing to do with compatibility. Bluetooth Corporation licenses its technology to many other companies. Devices using Bluetooth technology must conform to the Bluetooth standards. So, a Motorola Bluetooth device will definitely pair with your LG phone, or any other brand of phone supporting Bluetooth device communication.
Jan 25, 2010 | OEM Systems Bluetooth Headsets - Model...
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
249 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
