Tip & How-To about Computers & Internet
How to create a batch file ...
Did you ever get frustrated when you had to type a long list of commands in the command prompt window, even when those commands were already there on some site... I know it's very frustrating that ctrl+v doesn't seem to paste commands in the command prompt, but there is a way, and it's very very simple...
You can copy and paste those commands, to a new text document, and then select save as, hit the drop down menu where it says text document(*.txt), select all files, and name the file as filename.bat...
then just double click and run it from your desktop, or from anywhere else too...
you can execute the batch file in the recovery console as well ... just browse to the folder where the file is and type the name of the file
Good luck !!
Computers & Internet Logo
turned hibernation on in error .how do i turn it off again
You can turn it off under power management in control pannel. To avoid this issue in the future try this:
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window.
To make hibernation available, follow these steps:
  4. At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Jul 21, 2011 | Toshiba Satellite L670DST2N01 Laptop
what is the ip address of my dell dimention 2400
To find out your IP address you need to access the command prompt. To do that, click on the start button, click on accessories and then click on command prompt. Then type in ipconfig and hit enter. That will give you your ip address.
Thanks for using FixYa!
Jul 11, 2011 | Dell Dimension 2400 PC Desktop
How to active the Hibernate at all PCs?
Mar 26, 2011 | Computers & Internet
won't go past window xp logo
You will need to launch Windows XP Recovery Console..here are your to options you have to perform this to correct your boot issue..
Option 1: If you have already installed the Recovery Console loadTOCNode(2, 'moreinformation'); If you have already installed the Recovery Console, you can select it during your usual Windows Startup. To run the Recovery Console:
  1. During Startup, select Recovery Console from the startup options menu.
  2. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  3. When you are prompted, type the Administrator password.
  4. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  5. At any time, you can type Help for a list of available commands.
  6. At any time, you can type Help commandname for help on a specific command.For example, you can type help attrib to display the help on the attributes command.
  7. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
uparrow.gifBack to the top Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM loadTOCNode(2, 'moreinformation'); If you have not preinstalled the Windows Recovery Console, you can start the computer and use the Recovery Console directly from your original Windows XP installation disc. If your computer is already in Windows and you want to add the Windows Recovery Console as a startup option, go to the next section "Adding the Windows Recovery Console as a startup option."
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
May 21, 2009 | Acer Aspire 3000 Notebook
118 people viewed this tip
David Payne
David Payne
