Tip & How-To about Computers & Internet
How to fix update issues in windows ...
First of all, open an elevated command prompt, if u're using vista or win7 (right click on cmd and select run as administrator)
Then type in the following commands.. hit enter after each command...
net stop cryptsvc
net stop bits
net stop wuauserv
ren %systemroot%\system32\catroot2\Edb.log *.bak
ren %systemroot%\system32\catroot2 cat
exit
DO NOT RENAME OR DELETE ANYTHING PRESENT IN another folder named CATROOT, rename only the catroot2 folder
then click on start and browse to the folder
%systemroot%\softwaredistribution\
delete everything present in it
browse to the following folder
%systemroot%\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}
search for files tmp*.cat in it... delete them, DO NOT DELETE ANYTHING ELSE
now, we will unregister and re-register a few, 10 i believe, dlls
open an elevated command prompt once again,
and type in the following commands, or you can create a batch file ...
first we will unregister
regsvr32 /u softpub.dll
regsvr32 /u wintrust.dll
regsvr32 /u initpki.dll
regsvr32 /u dssenh.dll
regsvr32 /u rsaenh.dll
regsvr32 /u gpkcsp.dll
regsvr32 /u sccbase.dll
regsvr32 /u slbcsp.dll
regsvr32 /u mssip32.dll
regsvr32 /u cryptdlg.dll
exit
now restart the computer..
again open an elevated command prompt..
now we will re-register
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 mssip32.dll
regsvr32 cryptdlg.dll
exit
again restart
after restarting, in start search, type in, services.msc and hit enter
We need to check whether three services, namely,
Background Intelligent transfer Service (BITS),
Audomatic Update Service (wuauserv),
Cryptographic Services (cryptsvc);
are started and set to automatic or not, if not start them, and set the startup type as automatic...
Now perform the updates again, and the issue should be resolved...
Computers & Internet Logo
how do i become admin on command prompt?
Log in using the administrator account or/and right click it, select "Run as administrator".
Feb 07, 2014 | Microsoft Windows Vista Ultimate Edition
checkdisk /r will not run due to insugfficient priviliges
You should run the command from an Elevated Command Prompt. Running the Elevated Command Prompt is running the Command Prompt with administrative privileges. To run elevated Cmd, right click on Command Prompt or cmd and select run as administrator.
Hope this helps, Mrityunjay.
Jun 27, 2012 | Samsung N150 Netbook
winclonisuneadable
To run Disk Check facility, you must run elevated command prompt and type 'chkdsk' and press enter. Now windows itself will try to figure out any problems related to your hard disk.
Note: To run elevated command prompt, go to "cmd" or "Command Prompt". Right click over it and select "Run as administrator". Now the window of command prompt in administrator mode will open.
Hope this helps,
Mrityunjay.
Jun 03, 2012 | Samsung N13013B Netbook
I can't get rid of a document queued on my Dell 926 printer.
Open a command prompt (go to Start ' Run, then type cmd) and enter the following:
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator.)
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
Feb 12, 2011 | Dell 926 All-In-One InkJet Printer
error8007000b
Here's a fix for Windows Vista Update Error 8007000b and it works (I tried it)
1. Open an Administrator command prompt by right clicking on Start -> All
Programs -> Accessories -> Command Prompt and selecting "Run as
Administrator" and clicking "Allow" for the elevation prompt
(or use run->cmd)
2. In the command prompt, type the command below
cd\
3. Then type fsutil resource setautoreset true c:(If your vista installation is in C: drive)
4. It should say it was done successfully
5. Reboot your system
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
143 people viewed this tip
David Payne
David Payne
