Tip & How-To about Computers & Internet
Speeding up your slooooooooooooow Computer
As an IT Technician one of the most asked questions is "how can I speed up my slow computer?" So I thought I would write a quick tip to try which can improve performance dramatically. Sometimes you will need to upgrade the hardware of computer by increasing the memory but this is a useful tip to try first and can save you a fair bit of money!
The tip below will minimize the amount of programs that are running when you switch on you computer. Most programs set themselves to run when you log-on your computer and this isn't needed in most cases and will just slow your computer down, so try the following and see if you can notice the difference:
Click start then run, then type msconfig and press ok and you will see a box appear.
Click on the startup tab along the top and all the things in the list that are ticked are running when you start up.
Check the name of each ticked item to make sure you know what it is is and if you don't need it to run at startup untick it. Things like itunes, adobe speed reader, quick time task etc aren't needed at startup and can be opened just the same by double clicking the program as usual when needed.
You may need to run a few tests by unticking what you think and restarting your computer, you may be missing something you need or you may even be able to select more to not run at startup. A few attempts at this and you should end up with a setup you are happy with and a much faster computer
Computers & Internet Logo
very slow hp8730w
try to do a ram test and an hdd test
Jan 19, 2013 | HEWLETT-PACKARD HP EliteBook 8730w Rugged...
How to speed up windows xp!
Do you try clean registry? I recommend you use Registry Easy to repair it. Registry Easy also support Vista. You can download it from this web page http://www.keep-pc-clean.com/
Mar 08, 2010 | Computers & Internet
I have a Canon Rebel XS 1000D, I am having issues with my 18-55 lense. When I try to take a picture in AF it flashes but then says it is busy. What should I do
I hate asking a question to answer a question but, did you get a picture after the camera finished flashing busy? Were you using one of the program modes like portrait, close up, landscapes and so on or were you in a creative zone such as manual, AV, TV or P? Here is a good link to a review on your camera http://www.dcresource.com/reviews/canon/eos_rebel_xs-review/ it might help solve your problem. The Rebel XS is a 10.1 meg camera which is a sizable digital file my thought are it could be possible the camera is still writing the file to the media card. If the internal flash was used then the processor is writing to the file and using power to recharge the flash. It could be that the battery is low and it's taking longer to recharge the flash giving the "Busy" warning The Rebel processor is pretty darn quick and it has a decent size buffer so the write speed shouldn't be giving you a problem unless you have put some type of slow media card in it. In that case it wouldn't matter how fast the camera is if the write speed of the card is low. Also the Rebel has several "quality" settings for pictures and the higher the quality the slower it will be to process but, the Rebels processor is darn quick so this shouldn't be the issue
Dec 01, 2010 | Canon EOS Rebel XS 35mm SLR Camera
slow pc
Using different products for anti-virus, firewall and anti-adware is fine in itself. I am not sure if you mean that the downloading is slow (which can be if you download all these programs at the same time), or if you PC is slow in general.
Personally I used a lot of speed tweaking tips from www.PCauthorities.com Some is advanced, but a lot is easy to understand.
Jul 31, 2008 | Computers & Internet
117 people viewed this tip
David Payne
David Payne
