Tip & How-To about Microsoft Excel for PC
Script to extract URLs in Excel Spreadsheets
The following script could be used to extract the actual URLs from the text link in an Excel spreadsheet. The script writes each URL in the cell next to the text link:
Sub main()
Dim h As Hyperlink
For Each h In ActiveSheet.Hyperlinks
h.Range.Offset(, 1) = h.Address
Next
End Sub
Here is how to use the script:
1. On the "Tools" menu, point to "Macro", and then click "Visual Basic Editor". This will open the Visual Basic Editor in another window.
2. On the extreme left, you will find the "Project - VBAProject". Double-click the icon named "Sheet1 (Sheet1)", "Sheet2 (Sheet2)", or whatever the name of your worksheet. This will open a blank window. Copy & paste the script into this window.
3. Press F5, then click on "Run".
4. Go back to your Excel window. You will now find the URLs listed in the next cell to the original one with the hyperlink.
Microsoft Excel for PC Logo
How do you erase text from a pdf file?
Chances are you're using Acrobat Reader to read the PDF (portable document format) file.
You need Acrobat "Writer" (aka Distiller) to actually make changes to a PDF file, as the reader can only read the image file itself.
Jun 19, 2010 | ScanSoft PDF Converter Professional...
Excel 2000 Issue???
.Let's start with this for more info:
Is the URL icon there but blank? (Maybe an X in the middle of the box?) If it's there, do the following:
Right-click on the URL
2. Select Hyperlink from the menu that appears
3. Is Remove Hyperlink box checked or unchecked?
This is a setting that is machine-specific. Post the answer as a comment and we'll take the next step if necessary
Apr 02, 2009 | Microsoft Office 2000 Professional for PC
write into excel format
You can use ADO or SQL to open the excel file directly (provided it is constructed correctly, ie fields names) and write the data to it without Access.
That might be eaiser thatn converting it from Access to Excel, if that can even be done.
Feb 17, 2009 | Microsoft Visual Basic 6.0 for PC
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
Conditional Formatting
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
1,210 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
