Tip & How-To about Televison & Video
Convergence Repair for most 2000-2006 Panasonic Projection sets
I have had so many people with this kind of problem ask that I have composed the following instructions:
If picture looks 3D and in the customer menu convergence is skewed or red or blue will not move in some direction here is what is needed to fix this problem.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PANASONIC CONVERGENCE IC REPLACEMENT:
What you will need;
Two new STK-392-110 convergence Ic’s
Solder
Liquid solder flux
Desoldering braid or wick
A good soldering Iron
Some denatured alcohol
A small toothbrush
A Philips screwdriver or screw gun to REMOVE SCREWS
A PAIR OF GLOVES
  1. UNPLUG TV SET.
  2. Remove back cover of TV set.
  3. Remove entire front speaker grill on set(it pulls off and may resist being removed)
  4. Locate and unplug speaker wires (they are plugged into the main circuit board).
  5. Locate three cables with wires that come from the Front keyboard—two of them have to be unplugged from the main board(all plugs are different sizes but note where they go)
  6. Remove 2 long philips silver machine bolts from the front of the set (behind the grill).
  7. Remove 4 more in the back of the set; two are located at the extreme back edge of the plastic frame and hold the chassis down; two more are located on either side and also go straight down; note which are which and set them aside.
  8. Using gloves pull the entire metal box (it is called a light box) out of the set; there are hand holds on either side—careful as the metal has sharp edges.
  9. Remove the box from the set and locate the two Convergence IC chips; they are located on identical metal heat sinks with fins and they should have the STK-392-110 number clearly printed on them in white (they are black)
  10. Turn the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid for this—get all the pins completely de-soldered.
  11. Inspect the dozen or so light blue resistors in front of them; most are marked 2.2 ohms—if any are white in the middle you will need to replace them at the same time; best way is to check all of them like checking a fuse----they protect the set if one of the STK’s shorts in any way.
  12. With the STK’s completely unsoldered turn the box upright and remove the two screws on each IC. If the chips have never been replaced you will need to tap them loose with a putty knife or flat bladed screwdriver.
  13. Remove both IC’s.
  14. Apply heat sink grease to the two new IC’s and install them one at a time; this part can take some time and it is important the pins on the new IC’s are perfectly straight---once you get them in, Hand tighten both the screws on each IC---do not use a screw gun—you can strip the screw holes out. Clean the bottom of the circuit board where the chips were soldered with some denatured alcohol and apply liquid solder flux to all the pins.
  15. Presuming you have already found/replaced any bad resistors turn the box back over and solder carefully both of the two new IC’s in, --do not short any of the pins to each other when you do this and when you are done it is a good idea to take a close look at both to make sure all pins are soldered and not touching each other with soldering you have just done. I suggest you do clean the pins on the bottom of the circuit board again with denatured alcohol.
  16. Slide entire light box back into the cabinet.
  17. Reconnect the plugs you removed when you removed the box. At this point take a lens cloth or a paper towel with glass cleaner sprayed on it and clean the three large black lens-if they are dusty the picture will be darker and not as clear as is should.
  18. Position the box so it is all the way in place and none of the wires or plugs are pinched.
  19. I usually at this point turn the set on before I replace the Six bolts that hold it in—2 from the front and the four in back----this way if you have a problem you can remove the box faster.
  20. If the set comes on and now has normal Convergence go into the customer menu and adjust the convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set usually offers is a green cross in the middle of the screen—do not adjust Green!
  21. Once you have the Red and Blue in the center adjusted find the second convergence mode---it will give you 8 or nine points on the screen with instructions on how to change from blue to red---use the original remote with the thumb wheel or cursor buttons to adjust.
  22. NOTE: SOME of these sets need to have the Convergence adjusted in first: full/4:3 and second in the other two zoom/wide zoom and third on the HD input with a HD signal coming in. There is also an option at this point to go into the Technical menu and fine adjust the convergence all over the screen—if you need this I can give you instructions based on the model you have—most of the time adjusting the set in the customer mode will produce a good result.
  23. I know all this may seem complicated to you, but this repair should take about an hour or so and just take your time when you get to adjusting the set.
  24. If all looks good turn the set off and Unplug it; install all 6 of the chassis bolts back; replace the back cover and the Speaker grill and plug the set back in.
  25. You may find it useful to go over the convergence Adjust again—to get all the points as good as you can. There is a hidden Tech menu that will allow a finer adjustment of the entire screen----it is somewhat difficult to access and there are a lot of buttons on the remote that then do different things.
  26. Most of the time adjusting in the customer menu will give you a very acceptable picture.
I also have similar step by step instructions for Mitsubishi sets made around the same time as these sets.
Televison & Video Logo
I have an old Panasonic X400 at good condition that needs to be unlocked
Hello. Are you asking unlock for your Panasonic X400 cell phone? If so, what kind of unlock are you asking for? If it is a network lock, you can unlock it safer and easier using unique unlock code. You can get the unique unlock code for a Panasonic X400 from WickedUnlock.com at affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch ON your Panasonic X400 with an ACCEPTED SIM Card.
2 - Compose : 52824**.
3 - A new menu will appear, select "NCK".
4 - Enter the Unlock Code.
or
3 - Compose : 746 and press 2 times the button "OK".
4 - A new menu will appear, select "NCK".
5 - Enter the Unlock Code.
Nov 20, 2014 | Cameras
pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
The picture looks like it's in 3D
Your convergence is off. You should have a convergence adjustment feature on the menu screen. Very easy to follow.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
98 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
