Tip & How-To about Audio Players & Recorders
How to "Unfreeze" your iPod
If you have owned you iPod for about a year, you will notice that it will freeze up every once and a while. If it has not done this yet, believe me, it will. When it happens you will probably panic, like I did. But don't, there is a simple way to unfreeze it that works almost every time.
Resetting your iPod
Hold the middle button(select button) and the "Menu" button on your iPod down for about 7-10 seconds, or until you see the Apple logo appear in the middle of the screen.
Wait for iPod to start back up. Now it should be working properly.If you own an iPod Touch then hold down the "Power/Reset" button(the one on top) and the "Home" button(the one on the front with the square in the middle) for at least 10 seconds or until you see the Apple logo.
Restoring your iPod
If this does not work, you can try "Restoring" it. When you restore an iPod, you are extracting the "Flawed" software and putting new software back onto it. So first plug your iPod into your computer, then open up iTunes and select your iPod in the list of devices to left. Now right under the big picture of your iPod you'll see a button labeled "Restore," click it. Restoring will wipe all your music, movies and pictures off of your iPod, but if you restore you iPod on the same computer that you sync it too, then you'll be fine, you just need to re-sync your iPod once you're done restoring your it. Restoring will take about 10-15 minutes.
Hope this helps!
my new ipod pink nano 8gb keeps freezing
First you have a bad port on computer you probably need to plug your cable in the back of the computer. If you keep letting your ipod freeze like that your going to seriously mess it up. I'm going to teach you a way to fix your problem with freezing. the next time your ipod freezes hold the "MENU" and "CENTER" button at the same time. After that you need to take your ipod and restore it through iTunes. Please rate this response I would like to know if I helped.
Apr 13, 2009 | Global Baby Once Upon A Dream Musical...
NEW IPOD TOUCH FREEZES!!!
you need to restore it either with itunes or manually if manuel hold home for 5 seconds dont stop while holding it put in you usb connecter your usb  connecter must be connected to the computer
Nov 19, 2008 | Apple iPod touch
how do i download my own songs to the ipod
download the latest version of itunes from here
http://www.apple.com/itunes/download/
Then install the program.
Copy your music over to itunes either by copying your CD's or importing your music that you already have on your computer, you can do this by going to File>add folder to library or add file to library and go to where your music is and import. This will convert your music to be played in itunes and to be recognised by your ipod. Once you have done this, create a playlist of music that you want on your ipod. Go to File>new playlist. and rename the playlist to a name more suitable. Then select which songs you want on your ipod by righ-clicking the song and send to playlist, select the playlist that you just created. Once you have your playlist and are happy that you have all of the songs that you want, plug your ipod into the computer, itunes will pick the ipod up and load the necessary drivers for it. You will notice a little picture of your ipod on the left hand side of the screen, click on it then click on and update your ipod with your playlist.
I hope this helps
Nov 18, 2008 | Apple iPod nano
Ipod won't sync to Itunes
Hey try plugging in your ipod and then go to the ipod thing and hit restore ipod and then once it is done then try to sync your ipod
Sep 08, 2008 | Apple iPod nano
skipping songs
i bought new songs on itunes and i got a notice when i was syncing my ipod that said "the file or directory is corrupted and unreadable" and now my ipod skips over the songs i just bought.
May 10, 2008 | Apple iPod MP3 Player
751 people viewed this tip
 Grubhead
Grubhead
