Tip & How-To about Refrigerators
Items not working properly
On most electronic items built now adays the first thing to do is unplug the power for appx 1min and plug back in what this does is reboots in essence the main pcb or controller of electronic mfg items and may indeed resolve your electronic problems yes even try this on you dvd players, cd players, ect....
Refrigerators Logo
the printer does not reboot when power plugged in.
Try using these steps to resolve your issue.
  1. Unplug the power cable at the back of the printer
  2. Wait for at least 1min.
  3. Plug the power cable back in to the printer and on the other end of the cable, make sure that it is plug in directly to the wall outlet (please make sure that you are not using any power strip or surge protector.)
  4. If its still not working try using different cable.
  5. If its still doesn't work, call HP and have your printer trade in. ( 1-800-474-6836 )
NOTE: If your printer is no longer covered by the warranty and you are asking for replacement, charges may apply.
Feb 19, 2011 | HP PSC 2210 All-In-One InkJet Printer
NO VIDEO FIRST THING IN MORN GREEN LIGHT ON/OFF
hi zackmann37! I will be glad to assist you on this issue. 1st lets try to isolate the problem, unplug the power of you dvr receiver from the power strip or surge protector and leave it unplug for 1min. after 1min, plug in directly to the power outlet not on the power strip or surge protector. Why? some of the power strip does not give the 100% current needed by the dvr system thats why its malfunctioning, it gives the 100% power voltage but not the 100% current. then let the dvr reboot by itself once its rebooting you will see attention 015 then it will go on a progress until it download the programming guide and you got you tv shows, observe it until the next morning, leave the dvr plug in directly to the wall, now before you sleep, turn off the receiver by pressing the power buttonon the remote to turn off the green light. once you wake up in the morning, press the power button and the green light and the amber light will turn on and it will show your program, but if the problem still exist, you need to call on 1-800-333-3474 talk to dish tech support and tell them that you need a replacement receiver, you have a dvr lost of function. pls feel free to get in touch if you have any query
Sep 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
the washer will not turn on
if this unit is electromic style then unplug from wall about 1 min then plug back in this will reboot the cpu on the washer if still not work make sure the soap disp is push in all the way and last thing to check do you hear the door switch clicking when you close the door if not door switch is broken and was cause by closing the door hard ( ALL THINGS NOW ADAYS ARE PLASTIC)
Aug 20, 2009 | Samsung WF203ANW Front Load Washer
zanussi washing wjs1397w machine not working
john, as with all electronic items you should unplug for 1min then plug back in and attempt normal selections.
Aug 19, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Speedo not working corectly
This is an electronic speedo, could be several things but probably 1st and easiest thing to try is repalceing the vehicle speed sensor(vss). Also need to know if check engine light is on, and if any other electrical items are malfunctioning.
May 31, 2009 | 1997 Toyota RAV4
127 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
