Tip & How-To about Cycling
Bicycle grip installation and removal
Putting bike grips on can be a hassle. Taking them off has a habit of destroying them. We're going to use hairspray to fix that problem.
For new grips, just spray a quick shot of any hairspray into them, twist them on and let them sit for 10 minutes or so. You're done!
To take old grips off, without destroying them, insert a small screwdriver or allen wrench between the grip and handlebar. Push/wiggle it in as far as it will go and lift up to make some air space under the grip. Spray the hairspray into that space, pull the tool out and twist the grip back and forth until it starts turning freely. Now, just pull it off.
Rubbing alcohol works well, too.
Cycling Logo
handlebar grip needs to be replaced
Any bike shop should have those. You may have to split the bad one with a razor knife to get it off. You may want to use soapy water to make putting the new one on easier.
Mar 09, 2014 | Mongoose Maneuver Mountain Bike
How to install new hand grips on a bicycle?
oddly enough cut off old ones and use hairspray to slide on the new ones and when it dries you got the best seated grips in town ok :)
Apr 24, 2011 | Cycling
how to install bar ends on a bmx bike
If your grips have closed ends, cut a section off so you have plenty of grip left, but a hole where the bar ends can go through. Follow below procedure with the bar ends.
Bar ends are either have a screw or allen key head. Tap them into the ends of the bars with a rubber mallet. Tighten up the screw/bolt as this will make them expand keeping them inside the bars.
If you need to remove the grips:
Get some hairspray and lift the edge of the handlebar grips up, spray down until the grip is slippy and comes off. (Only use hairspray though, as once it is slippy, it will be very sticky in a minute so it will help when you replace it. Repeat for the other grip. Clean up the bars where the grips were. Refit the grips with more hairspray inside the grip and a little on the bars. Slide them on and leave for a good 6 hours so they stick.
Hope this helps mate, please vote for me :)
Jul 02, 2010 | FEDERAL BMX Bike Grip Red Nylon Bar Ends
cannot remove handlebar grips
Pry under it with a flathead screwdriver, athen pray it with hairspray,and turn on it until it comes off.
Mar 27, 2009 | 2005 Suzuki Boulevard C50
installing new grips
I use hair spray. -Cut the old ones off -Soak the clip-on (left) w/hairspray -Quickly slide grip on and align. Once it is aligned allow it to dry. -Soak throttle tube (right) with hairspray, slid grip on, align, and allow to dry. I guess this is probably a bad time to tell you about the R1 throttle tube (or BRG throttle tube) mod. It's a bigger throttle tube which means less twisting to go WOT. Late model Gixxers are notorious for a long twist to go WOT.
Nov 10, 2008 | 1989 Suzuki GSX-R 750 RK
268 people viewed this tip
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
