Tip & How-To about Computers & Internet
Remove autorun virus without antivirus
You can remove your autorun virus without using any antivirus software.
Click on start and then click on run and type cmd and then press enter
write the command according to your required hard drive.
D:/>attrib -s -h -r autorun.inf (and then press enter)
D:/> del autorun.inf (and then press enter)
Now take a reboot and after rebooting autorun virus will have been removed.
Note:
You can remove autorun.inf to using this process from the USB.
Good Luck
Computers & Internet Logo
i for all you!! i ned know how to remov shortcut virus in my pen driver?plz someone help me plz...thankyou zener- from mozambique
Use antivirus software like avast ,microsoft security essentials and scan your pendrive to remove your virus ..If you want to remove virus manually then FOllow these instruction
1)click start
2)then go to run
3)and type "cmd" in the text box without quotes
4)command prompt will appear
5)press enter
6)type "cd\" and then press enter to get into the root directory
7)Now assume that your pen drive has drive letter G type g: and followed by enter then
8)Type "attrib -h -r -s autorun.inf" and press enter. This will look for autorun.inf in the selected Drive.
9)Type "del autorun.inf" and press enter. This will delete autorun.inf virus from the selected Drive.
If this doesnt work and if you have newfolder.exe virus then try the software called SRT tools to remove it.
I hope this will help you .if it does do rate my answer
Thank you for using fixya
regards
lalith
Mar 15, 2011 | Online Computers & Internet
whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
funny scandal ust.avi.exe...virus problem
How to remove this virus:
-first download taskiller in http://www.rsdsoft.com/task_killer
and install it to your computer because you cant use taskmanager to terminate the virus(the virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Hope this helps!
Brad Nelson
Mar 15, 2008 | Computers & Internet
funny UST scandle.avi (Virus)
I done research on this but not tested to my computer ..just try this remover created in philippines . this the link: http://www.geocities.com/six519/Remover.zip may this help.
Dec 11, 2007 | Computers & Internet
UST Scandal.avi.exe
1. Start Notepad
2. Copy the following text. (note: Everything in between the square brackets should be in one line)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\IniFileMapping\Autorun.inf]
@="@SYS:DoesNotExist"
3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part)
4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear.
But what if you are already infected with the virus? There are several programs on the internet that you can download. Here are some of those programs that can be helpful:
Taga Lipa Are Remover (or Noob Killer) by Leerz (<--click to download)
else
first download taskiller in http://www.rsdsoft.com/task_killer/index... and install it to
-click processes
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
CMD STEPS
-delete lsass.exe
-thats all
(* from support forume)
Nov 22, 2007 | Computers & Internet
188 people viewed this tip
David Payne
David Payne
